My car also failed for these reasons:
-near side head lamp not working on dipped beam
-offside front lower axle swivel joint has excessive movement between a swivel joint and its housing
-near side front floor subframe mounting prescribed area is excessively corroded
-parking brake efficiency below requirements
I have also found a dodge connection behind the headlight which explains why it was dim.
All these faults are mostly fixed now :)! Should get them all finished by mid tomorrow morning and then hopefully retest mot same day
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sideways.gif)
