Part 5 The Fast Road Mini Pedro
#46
Posted 25 November 2014 - 12:26 PM
are the much more effective than 4 pots?
#47
Posted 25 November 2014 - 06:22 PM
I didn't know 6 pots fitted under 10's.
they fit with a little room to spare very sharp brakes i have the mad pearl box fitted which give great adjustment front to rear and means the hydraulic handbrake works great as the front and the rear run on different cylinders
#48
Posted 25 November 2014 - 08:03 PM
Keep progress pics coming mate :)
#49
Posted 29 November 2014 - 11:18 PM
Looks like you have money to burn with the spec of this haha
Keep it up
#50
Posted 14 December 2014 - 02:59 PM
hi eventually a bit more work done been busy with my 14 year old son rallycar and getting him started
video of him testing
got the newly built engine in place all steel 1380 cc light weight flywheel race spec gas flow head and med rally cams
specialist componets carb in place a minor bit room to make it fit perfect . need to bend bottom of the bulkhead very slightly to give it bit of room for engine movement
got the new hydraulic handbrake fitted looks good
#51
Posted 14 December 2014 - 07:46 PM
how is that brake fitted? im seriously considering getting one and was wondering, someone said to me once about one way valves but surely that would just lock the rear brakes permanently? is it just a bias adjuster? Cheers
#52
Posted 14 December 2014 - 08:28 PM
hi it replaces the brake master cylinder with two master cylinder one for the front and one for the rear with a bias adjuster so you can put more or less to the rear it allows the hydraulic handbrake to work with our affecting the front. it is very ay to fit just bolts on mad make cylinder the size to match your brakes .
#53
Posted 14 December 2014 - 08:37 PM
do you have any pics of the whole system as to be honest im lost, pm's might be a good idea as to not clog up your thread :)
#54
Posted 14 December 2014 - 08:40 PM
hi will take some photos latter in week of the plumbing of master cylinders will be wednesday before iam home
#55
Posted 14 December 2014 - 08:45 PM
okay cheers cben123 :) i look forward to it!
#56
Posted 09 January 2015 - 10:27 AM
power steering now working
twin brake cylinder system
New gear lever
#57
Posted 09 January 2015 - 10:26 PM
MAD! was it all custom fabbed or bought?
Edit*
the twin master cylinders that is
Edited by steah, 09 January 2015 - 10:26 PM.
#58
Posted 11 January 2015 - 09:46 PM
made by KAD 3/4 inch front cylinder 1 inch rear cylinder
#59
Posted 23 March 2015 - 10:16 PM
got a bit more work done wiring nealry finished
power steering wired and full working
fuel pump wired with relay on ignition sysytem
lights all wired and working
new fuse boxes wired and kad pedal box dual master cylinder fitted and plumber
ecu for fuelinjection fitted and wiring loom finished
jobs to do
fit oil cooler
finish fue lines
car to rolling road to set up ecu
new wiper motor
bleed brakes
fit carpet and seats
fit rally dash panel
set up suspension
#60
Posted 24 March 2015 - 05:49 AM
looking fantastic!
How does the power steering gubbins affect pedal access? It looks a bit tight under there
Ben
