Stiff Clutch Pedal
15 replies to this topic
#1 PRG123
PRG123
  • 53 posts
Posted 25 May 2013 - 07:26 PM
Hi,
Please help.... I'm the least mechanical person there is.... The clutch on my 98 mini cooper has started to get gradually stiffer How do I go about fixing it?
Many thanks
Pete
Edited by PRG123, 25 May 2013 - 07:27 PM.
#2 PRG123
PRG123
  • 53 posts
Posted 02 June 2013 - 06:37 PM
Any ideas?
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 02 June 2013 - 07:28 PM
check the system for fluid(cylinder next to servo/ master cylinder), it could be empty, if it isnt, try bleeding the system first there colud be air in the system
#4 PRG123
PRG123
  • 53 posts
Posted 03 June 2013 - 05:14 PM
Ok thanks ill check that..... There is also a noticeable squeak when I depress the clutch
#5 jamesmpi
jamesmpi
  • 1,940 posts
Posted 03 June 2013 - 06:01 PM
That sounds like the clutch slave cylinder which is to the left of your engine below the brake servo. Could be leaking too if the clutch is playing up. Check for signs of fluid loss
#6 PRG123
PRG123
  • 53 posts
Posted 03 June 2013 - 06:18 PM
Ok checked plenty of fluid in ..... Also when pumping clutch lots of squeeking can't see any fluid loss
#7 Ipod
Ipod
  • 2,024 posts
Posted 04 June 2013 - 06:16 PM
Theres a brass bush in the pedal that the pedal shaft goes thro, that could be worn
#8 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 06 June 2013 - 02:51 PM
Try to identify where the sound is coming from, inside the car or outside in the engine bay.
As mentioned the pedal box area inside the car could be the source or perhaps more likely the clutch arm on the clutch side of the engine.
There are several components that need maintenance there and if they have been ignored may be quite rusty and causing a problem.
There are several pieces that also wear out and eventually need replacing especially if they have not been greased regularly.
Terry
#9 PRG123
PRG123
  • 53 posts
Posted 06 June 2013 - 05:51 PM
I think it's outside.... When I got my son to pump the clutch and I was outside it seemed to squeek from underneath the car when the clutch was depressed.
- Pete
Edited by PRG123, 06 June 2013 - 05:52 PM.
#10 jamesmpi
jamesmpi
  • 1,940 posts
Posted 06 June 2013 - 06:02 PM
I would say its the slave cylinder. My wife's Yaris has the same problem.
Can you watch it whilst someone else pressed the clutch pedal. That will tell you if it is the slave cylinder, or not
Edited by jamesmpi, 06 June 2013 - 06:04 PM.
#11 Alex_B
Alex_B
  • 4,573 posts
Posted 06 June 2013 - 06:05 PM
its going to be the pivot point between clutch arm and slave cylinder, it needs oiling to avoid friction, its located on the left hand side of the engine bay on the clutch housing :)
#12 miniyellowmini
miniyellowmini
  • 595 posts
Posted 06 June 2013 - 07:55 PM
I agree with Alex_B likely to be the pivot point I had identical problem just a week ago. Quick squirt of WD40 or a few drips of 3in1 oil should fix it
#13 PRG123
PRG123
  • 53 posts
Posted 08 June 2013 - 05:46 PM
Ok pivot point do I get to that underneath the car?
( sorry for being dim! )
#14 Ipod
Ipod
  • 2,024 posts
Posted 08 June 2013 - 06:03 PM
look into the the engine bay. on the left by the clutch housing, you will see the arm by the slave cylinder, if what the other posts mean by pivot point
#15 miniyellowmini
miniyellowmini
  • 595 posts
Posted 08 June 2013 - 09:34 PM
Thats the one, it can be seen in this picture on the side of the clutch housing
