I understand now!The idea of different settings on pressure switch is to avoid high current surge being same on both, no problem with them set at different pressure, if not much air being used then the one compressor keeps the tank full, if it can't keep up with demand then pressure drops slightly more and the second one kicks in to keep up with demand. It's a proven method that works. Just make sure both compressors are rated to same pressure.
#31
Posted 26 May 2013 - 11:04 AM
#32
Posted 26 May 2013 - 11:11 AM
I just bought one of these for the garage to power guns, die grinder and small HVLP for spraying blocks etc... More than up to the job, very portable, small foot print and very keenly priced....
https://www.facebook...&type=1
That looks like a really good idea. I've often thought about upgrading to a bigger compressor, but with a small single domestic garage, I really don't want to loose all the extra space that a bigger one will inevitably take up. This upright version could well be the answer though!!
How does it cope with air tools?
This is what concerns me, i like the idea of it taking up less space than my current monster but 10 CFM won't run my high speed grinder properly along with some of my drills. Still its a nice compact size. The Americans run some very nice vertical compressors at very reasonable prices as well. Shame they are not usable here.
10cfm is ok for domestic applications, any more than that and you need a 16amp supply which most domestic installations don't, other than for a power shower or cooker.
For serious air power I have this in the unit... 15kw / 60cfm
I have a 14CFM on a 3hp, no additional wiring needed, but it is at the limit, the size is sold by virtually all manufacturers without any instructions to upgrade your electrical supply.
This is a grey area as when i started to have trouble with my compressor i queried the manual stating a 13 amp circuit would be sufficient. The Machinemart salesman argued the manual said you needed to upgrade the circuit but i showed him what the manual said so he shut up then. I rang their tech guys and they said "yes it does need a heavier circuit to take into consideration the start up loads"
Now this may not be the same for all 3hp motored compressors but playing devils advocate here and what i went through upgrading a stand alone circuit just for the compressor cannot be a bad thing.
As i said i now have a split consumer unit in my garage just purely so i can keep thing separate. At least that way i know there will be no issues.
If you find it starts to trip then thats what will need to be done.
#33
Posted 26 May 2013 - 04:00 PM
#34
Posted 26 May 2013 - 06:15 PM
The belt driven one I have now 150 litre tank 14cfm 3 hp...Machinemarts webpage says must be run from a 30amp supply minimum
The one I had previous was a direct drive 60litre but also 3hp and it came fitted with a 13amp plug
#35
Posted 27 May 2013 - 09:15 AM
I agree it is best practice to beef up the electrical supply, especially if you are running electrical heating off the same circuit. I bought mine 2 years ago and whilst Machine Mart do specifically advise to upgrade to a 30amp circuit they did not 2 years ago, for example here is one today and no suggestion.
http://www.machinema...-air-compressor
At the end of the day you don't want to have any hassle's in the middle of a respray, maybe also its how old or what condition your existing wiring is??
#36
Posted 22 April 2014 - 09:30 PM
Figured i would post on this thread instead of making a new one.
I have been looking at all the threads on air compressors on here as i am thinking of spraying my mini myself with my father.
So the specs i have gathered i needed is 100L tank, 7cfm,8bar,3hp generally things along them lines
So i have found a couple and would just like an opinion as the first link is £100 cheaper as it is not a name brand and the second is so i was just wondering if its worth paying the extra £100 for the name/quality or will the other be as good. Im not trying to be cheap but not being wasteful either.
http://www.machinema...tre-air-compres
Thanks Andy
#37
Posted 22 April 2014 - 10:30 PM
Thanks Andy
Ive just purchased this one for just £214 and it arrived today - http://www.frost.co....compressor.html
It was recommended by Guessworks over on another thread and as its quite space saving this appealed to me
compressor.jpg 28.44K
3 downloads
The day after I placed my order the company (Frost) offered there Easter savings offering an extra 10% off (typical lol) This offer ends 12pm tonight !!
Enter 144EASTER at the checkout to receive the discount.
#38
Posted 22 April 2014 - 10:56 PM
Ahh that looks brilliant for the price mate thank you ( and thanks you Guessworks )
will probably end up buying that soon :) best one i have seen so far.
#39
Posted 30 April 2014 - 06:24 PM
Thanks Andy
Mate just quick question did you need an adapter for the outlet to hose or do you know what size hose is need to buy with this .
#40
Posted 30 April 2014 - 07:04 PM
Thanks Andy
Just the standard size mate 1/4"
http://www.ebay.co.u...984.m1439.l2649
#41
Posted 01 May 2014 - 08:00 PM
Thanks again mate
#42
Posted 01 May 2014 - 08:30 PM
If anyone is interested and only has access to 2 x small compressors I had a thread going on the Mig Welding Forums asking for advice on connecting them together, the thread also has info on fitting water traps etc.
Its located here
I also started a thread on what compressor to get, the thread contains advice on spraying with a small compressor.
Its located here
IMHO if you have the cash go for a compressor that will be up to the task of a standard size spray gun!! I don't have that option at the moment i'm afraid so I have hooked up 2 x 2HP, 25Ltr, 8cfm Compressors so I'll have about 16cfm with 50Ltr storage running at whatever the highest PSI is for either compressor (think its about 118 PSI).
Also tagged with one or more of these keywords: paint
paint
Mini Technical Sections →
Bodywork, Paint and Detailing →
Identify The Oiginal Body Color CodesStarted by Vítor Brasil , 18 Feb 2025 ![]() |
Does Anyone Know The Colour And Colour Code Of This Mini?Started by Ryanrjstorey , 18 Feb 2025 ![]() |
paint
2K Or Not 2KStarted by BobbyMax , 28 Apr 2024 ![]() |
Looking For Original Paint Codes/colour SuggestionsStarted by BernardMini , 10 Sep 2023 ![]() |
Smoke Grey PaintStarted by aiden_hollis97 , 20 Mar 2023 ![]() |
