Which Compressor?
paint
41 replies to this topic
#1 mini-reub
mini-reub
  • Just Joined
  • 78 posts
Posted 24 May 2013 - 09:57 AM
Wise ones! I'm looking for a compressor that I can use for painting/various air tools and spotted this:
http://www.machinema...-air-compressor
It's VAT free at the moment for £180 which looks like an good deal.
Will this do for spraying with celly?
Thanks!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 24 May 2013 - 12:02 PM
Thanks!
It will work for spraying as i did my wifes mini with one like this many years ago.
However it will run quite a lot and also generate quite a bit of water so a decent moisture trap is a must. Without it you will end up with issues like micro blistering etc.
As for air tools its not really suitable as most decent tools like drills, grinders etc are air hungry. I upgraded to a 3hp motor 100 litre receiver unit which is a lot better and does not run as much but is still not perfect.
It really does depend on several factors, your budget being the biggest, the amount of space you have for a compressor, what you want to use it for and also the tools you are going to use.
#3 mini-reub
mini-reub
  • Just Joined
  • 78 posts
Posted 24 May 2013 - 12:51 PM
Ok thanks Sonik, I'll have a look around for a 3hp bargain
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 24 May 2013 - 12:56 PM
If you can stretch to it this one
Runs anything I throw at it.
Got mine in a seperate shed so noise isn't an issue but its pretty quiet anyway
Edited by lrostoke, 24 May 2013 - 12:57 PM.
#5 mini-reub
mini-reub
  • Just Joined
  • 78 posts
Posted 24 May 2013 - 01:15 PM
Yeah that looks good, guess i'm better off paying more but buying it once.. Learnt that the hard way after buying two welders!!!
#6 firstforward
firstforward
  • 824 posts
Posted 24 May 2013 - 01:38 PM
I have one of these and most pleased with it...
http://www.ukhs.tv/W...pc-Air-Tool-Kit
#7 mini-reub
mini-reub
  • Just Joined
  • 78 posts
Posted 24 May 2013 - 01:58 PM
Thanks for the tip firstforward, thats cheap for 14CFM..
#8 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 May 2013 - 02:57 PM
What you must remember with all of the ones we have suggested is the electrical rating of them. They will all need a 30 amp rated dedicated socket for them.
I have a split consumer unit in my garage with a circuit purely for the compressor. Initial start uploads are high and will trip a standard 13 amp circuit.
#9 firstforward
firstforward
  • 824 posts
Posted 24 May 2013 - 03:37 PM
This is a valid point, that said I have got away with  a standard socket and even used it with an extension lead (uncoiled) without any problems.
#10 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 24 May 2013 - 03:45 PM
http://www.kendaltoo...=showprod_06245
#11 Daz1968
Daz1968
  • 2,058 posts
Posted 24 May 2013 - 04:39 PM
The wolf one above has some good reviews but best to take outlet from receiver end not from the built in regulator, I went for a clarke industrial se16c100, same as the one above but smaller receiver, I use an air sander with no problems, I had it on a vat free voucher so was a good deal, also look in your local machine mart as they often have them in the clearance section. The larger receiver just gives added initial capacity if you are constantly using air once it dropped in pressure its still the compressor motor doing the work. I have had no issues with 100 litre capacity, although when I get an airfed mask I need to add another compressor as these with a spraygun consume a lot of air well outside a 3hp compressor capacity.
Edited by Daz1968, 24 May 2013 - 04:39 PM.
#12 mini=love
mini=love
  • 211 posts
Posted 24 May 2013 - 04:50 PM
If your painting, look for a bigger tank. But the one in the link you put up will do it...
#13 CK's mini
CK's mini
  • Just Joined
  • 113 posts
lidl have got a 2.5hp compressor at the mo and i'm sure it's only around £80. could get two and link them together. also i'm sure they come with a 3 year warranty so what have you got to loose.
#14 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 24 May 2013 - 10:59 PM
that's not free air though, chances are will be more like 10cfm
 when I get an airfed mask I need to add another compressor...
you'll need  bloody good filter setup for breathing air.
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 May 2013 - 07:48 AM
I just bought one of these for the garage to power guns, die grinder and small HVLP for spraying blocks etc...  More than up to the job, very portable, small foot print and very keenly priced....
https://www.facebook...&type=1
Also tagged with one or more of these keywords: paint
