Engine Conversion Ideas
27 replies to this topic
#1 lawrence
lawrence
  • 1,340 posts
Posted 22 May 2013 - 09:13 PM
Hi there people,
Now I know some people will say there are many topics like this but none of them are really aimed at answering my question
So,
I currently have my mini off the road, she will be going back on either at the end of this year or early next year. Bodywork and mechanicals she's pretty much sorted, however the engine is where she is being let down currently
She currently has the mg metro gta 72bhp engine with hif44 carb, mild cam, ported and polished cylinder head, lightened turbo clutch and quickshift. However the head has been skimmed a few times and when she was on the road the hg went every 3 months or so. In addition i did a compression test some months ago and the two middle cyclinder are down 40odd psi, i recollect 120,80,80,120. To add to that the gearbox needs a rebuild sometime soon as there's a lot of whining in a few gears.
So what my mini has is an engine that's hg goes all the time, will probably need piston rings etc and then a gearbox build. Around £400 I would say to get her fixed up.
Now my question is that when she's back on the road I intend to use her every few days to go relatively long distances a few times a week (approx 100miles ever 2 days)
So I was contemplating fitting a more reliable engine with 5 gears that does at least 405!
The choice of engines I've made so far are
-nissan micra 998/1275 engine (1990s)
-fiesta 1250 zetec engine (1995-2000ish)
-saxo (1990-200)
-Suzuki swift (1980-1990)
-Peugeot 106 (1990s)
-vw lupo
-smart car (800cc supercharged)
I'm basically looking at 1-1.6 litre small engines that will fit in a standard mini front,
(possibly with slight bodywork modifications)
Does anybody have any suggestions? Bear in mind I can weld etc and have mechanical skills to modify the engine to fit, please don't suggest hugely powerful engines as I won't be able to insure it (I'm only 21)
Thank you for any help
lawrence
#2 6joshh6
6joshh6
  • 224 posts
Posted 22 May 2013 - 09:27 PM
I'd scratch the smart car engine of the list, underpowered, unreliable and difficult to service. I've heard good things about the micra engines though and apparently they fit nicely too.
#3 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 22 May 2013 - 09:57 PM
Also the smart car engine is mounted diagonally under the car so you'd have problems with it sitting upright. I'd also rule out 106/saxo as I don't like them and they aren't as good as some of the other choices. I believe the zetec are too big to fit without major work. So that leaves you with swift or micra
#4 jeebz
jeebz
  • 155 posts
Posted 22 May 2013 - 10:00 PM
aren't the saxo and the 106 the same engines?
#5 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 22 May 2013 - 10:02 PM
1.6 vtec simple !!
It's popular for a reason;)
#6 jaydee
jaydee
  • 8,565 posts
Posted 22 May 2013 - 10:16 PM
Micra engine, i've heard about a swift engine too
Forget all the other engines you mentioned, especially that one from a smart car.......
#7 rids
rids
  • 670 posts
Posted 22 May 2013 - 10:28 PM
micra all the way, all mods on subframe, no body mods needed, so if you want to go back to "a" series its not a problem. good reliable power without losing the handling or feel of a mini
#8 Merryck
Merryck
  • 339 posts
Posted 23 May 2013 - 10:01 AM
1.4 Fiat 500 Abarth engine.
If you've ever heard the sound of the exhaust you'll know why. Puts out 165BHP iirc. It's the same base engine as the TwinAir but tuned and with a big ol' turbo on it.
#9 lawrence
lawrence
  • 1,340 posts
Posted 23 May 2013 - 09:28 PM
Thank you guys, so pretty much I'm looking at swift or micra. I'm leaning more toward the micra as they are easy to get my hands on! The fiat Abarth engine could be lovely but I may have trouble insuring it haha! :) and towards the 1.6 zetec I used to have one of those in my old escort but from what I remember it was a big engine, possibly too big to fit in the mini without a lot of work.
If anyone's got any ideas for other tho I would love to know.
Many thanks
lawrence
#10 ToM 2012
ToM 2012
  • 4,066 posts
Posted 23 May 2013 - 09:37 PM
what about the vauxhall 1.6 gsi engine? or 1.4 sport? to big?
#11 Gashmonster
Gashmonster
  • 75 posts
Posted 23 May 2013 - 09:54 PM
What about a small diesel turbo
#12 jmmini
jmmini
  • 711 posts
Posted 23 May 2013 - 10:14 PM
What about a 3 cylinder daihatsu turbo diesel?
#13 smartie93
smartie93
  • 285 posts
Posted 23 May 2013 - 10:18 PM
Yeah, do something different :)
The problem with the Ford set up is that a suitable gearbox isn't available, and the standard IB5 is bulky and requires a lot of work apparently.
General consensus is why go through all that hassle when a far more powerful engine is a lot easier to fit.
But if you want to show off your fabricating skills I reckon a Puma 1.7 would go quite nicely :)
#14 Stella87
Stella87
  • 151 posts
Posted 24 May 2013 - 10:18 PM
My mate told me that someone did a relatively cheap volvo turbo engine conversion...Z Cars do a kit as well I think :)
#15 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 25 May 2013 - 06:16 AM
I keep looking at going electric. Single large or 2 smaller motors, Bedford rascal diff, lithium batteries under the bonnet. You can get twist throttle units easy enough which could be modified with a simple linkage to the pedal. Everything held in a cage welded to the front subframe. Without any problem you could get 80+ miles range.
