Leaking Coolant?
Posted 21 May 2013 - 07:24 PM
Posted 21 May 2013 - 07:33 PM
How much is leaking? Check the level in the radiator (just undo the cap) and if you can't see water then some has leaked out. Has the car overheated or run hot at all?
In terms of where it's leaking out, I had this recently with the bottom radiator hose which goes from the bottom of the radiator to the water pump. It's weird shaped. You should be able to see the bottom of this if you look up into the passenger side front wheel arch and through the holes in the body work. You may notice it's leaking. Also check it from above, where it connects near the bypass hose it may be leaking, or the bypass hose itself may be leaking (the small vertical hose which often splits).
If you're lucky, may just need to be tightened up. If you are unlucky and a hose has ruptured then it will be a case of whipping the radiator/waterpump out (depending on which hose) and replacing it. Not a massively difficult job for you or a garage to do. Depends how confident you feel.
The other possibility is that the radiator overflow pipe - if you have one fitted - is leaking coolant because it's boiling up for whatever reason. Perhaps the radiator cap is loose and needs replacing. It's difficult to tell, you will need to have a close look all over for a trail of water or evidence of dried water drips. Just be careful not to burn yourself if the engine is hot.
Good thing is, I'm pretty sure there's no other green fluid in your car so it must be coolant. Unless your screenwash is green and on the wrong side
Edited by lewBlew, 21 May 2013 - 07:38 PM.
Posted 21 May 2013 - 07:35 PM
Coolant can be green. It sounds like coolant.
Start by looking at your rubber hoses, especially where they attach. Leaks will show up as crusty deposits (or wet coolant for a severe leak)
Another common culprit is the radiator itself if it is old and rusted. You will want to find any leaks right away before you loose your coolant and the poor thing overheats! You don't want to cause head damage!
Leaks are easy when they are still just leaks. Not so easy when they become a head skim and gasket change.
Posted 21 May 2013 - 07:46 PM
Posted 21 May 2013 - 09:50 PM
It may have been over-filled and have thrown the excess out of the overflow pipe.
