Jeez! Had to replace the engine mounting bracket (under the radiator) on my 1275 GT.
Getting the old bracket out was straight forward enough - remove radiator, cowling and fan, support the weight of the engine on a block of wood, extract the two long bolts that hold the bracket onto the engine, and finally remove the two bolts that hold the bracket onto the chassis. Bracket litterly drops out!
Trying to get the new one back on is a feckin nightmare! I have managed to secure the new bracket onto the engine with the two long bolts, but I simply cant get the bracket lined up to the chassis? I can get it to about half a bolt hole, but not enough to get the bolt through. So bloody close!!
Ive been at it for two hours now - there must be an easy way?
Im thinking that maybe I should have attached the bracket to the chassis first, then jiggled about to get the long bolts in?
Ive attached a wee pic that hopefully helps visualise!
Any advice anyone?
