Mini Shorty Featured in Mini Magazine Recently
Due to illness it's time to sell the shorty
Modified to very high spec the shorty is fitted with:-
Shortened bodyshell, deseamed, de-bumpered, wipac crystal headlamps flat indicators, Innocentti grille, MkI tail
lights, modded MkI bootlid, bootlid handle removed, internal boot and bonnet release, vents in valance and scuttle,
lightened boot hinges, flat boot floor, modded fuel tank, roof used to make deck lid, roll over hoops, shortened and modified
wind deflector, doors removed, F1-style mirrors, frenched side indicators, bonnet seam removed, dashboard vents removed,
ashtray removed, Savage switches, hidden wiring, Group-5 arches. Paint: Tweed Grey.
ENGINE 1380cc A-Series, 73.5mm pistons, Stage-4 cylinder head, Kent 286 camshaft, HIF 44 SU carburettor, K&N air filter,
MG Metro inlet manifold, Fletcher LCB manifold, Maniflow centre exit exhaust, duplex timing chain, uprated water pump,
electric fuel pump hidden in beer can, Megajolt distributorless ignition set-up, Ford coilpack, two-core radiator, six-blade
fan, oil cooler. Maximum power: 89bhp / 90lb.ft.
transmission MG Metro Turbo gearbox, four-pin differential, lightened flywheel, MG Metro Turbo clutch plate, grey
clutch diaphram, 3.44:1 final drive ratio.
SUSPENSION Hi-Los, Gaz dampers, poly bushed, adjustable tie-rods, bottom arms and rear camber brackets.
brakes MG Metro four-pot vented front discs, Goodrich stainless steel hoses, standard rear drums.
WHEELS AND TYRES 7x13-inch Ultralites, Dunlop SP2000 175/50x13 tyres, beer can wheel centres.
interior Cobra Clubman buckets, harnesses, Savage switches, customised speedo, Cooper 500 gearknob, tacho.
plus loads of other mods, tax exempt & MOT (till May 2014). £5250 ovno based in Bournemouth, viewings welcomed.
I am offering this for sale on behalf of my husband who unfortunately has had a stroke and can no longer drive the shorty. It would be much appreciated if only serious parties who are genuinely interested in purchasing the shorty comment or contact us, this is a very stressful time for the family and we would not appreciate negative comments or silly remarks. Many thanks for your co-operation.
