Has Anyone Done Air Suspension On A Mini?
8 replies to this topic
#1 junelmini
junelmini
  • 32 posts
Posted 13 May 2013 - 04:41 PM
im going to buy a set im looking around   anyone here has done it? any recommendations.?
i googled and found a few but  i just want to know if someone here has done it and is it worth it?
Edited by junelmini, 13 May 2013 - 05:09 PM.
#2 Tupers
Tupers
  • 4,143 posts
Posted 13 May 2013 - 05:08 PM
Go on youtube and search "Classic Mini Air Ride".  :highfive:
#3 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 13 May 2013 - 06:24 PM
Have a google there was a company selling a kit iirc
#4 junelmini
junelmini
  • 32 posts
Posted 14 May 2013 - 08:41 AM
i googled and youtubed  and found a few but  i just want to know if someone here has done it and is it worth it?
#5 RayBoogs
RayBoogs
  • 1,109 posts
Posted 15 May 2013 - 12:56 PM
Define what you mean by "worth it"
#6 joeyfinneran
joeyfinneran
  • 511 posts
  • Local Club: imoc
Posted 15 May 2013 - 10:40 PM
I just seen the airride uks video and you could get it lower on hi los.
Minis just cant use newer tyre suspension unless theres huge mods done
#7 iTomKart
iTomKart
  • 351 posts
Posted 15 May 2013 - 11:38 PM
agree, mine's lower than them on the front and it's static
Edited by iTomKart, 15 May 2013 - 11:39 PM.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 May 2013 - 06:35 AM
Depends what you mean by air suspension...
Do you mean "Pimp my ride" type air suspension or do you mean air suspension like that available in luxury cars.
I have a subaru legacy which has air suspension, and have been looking at using the rear bags from this system to mount into the rear subframe, but the issue maybe the amount of travel which is required for the system to work properly vs the amount of travel on the mini suspension strut. Obviously an air bag suspension would replace the shock absorber as well.
The reason for doing the above would be for self-adjusting suspension in my van, which would also be a pre-cursor to the installation of an HID headlamp system.
If you mean the former, then comfort must not be a consideration.
#9 nickadees
nickadees
  • 44 posts
Posted 18 May 2013 - 02:22 PM
If you just want it for the lifting lowering effect rayvern hydraulics used to do a kit not sure if they are still around tho.
