Accelerator pedal gets stiffer and stiffer to the point that it's as stiff/stiffer as the clutch.
It's also notchy the first few mm's.
I've been doing some reading:
1. Worn accelerator cable
- Using new Minispares (hif44) cable
2. Too close to manifold
- I tried different angles, got it the furthest without making a 90deg turn
3. Oil / Nylon - Will try oiling
- Not sure if related, because it gets stiffer the hotter the engine gets
4. Grounding issue melting cable
- Cable was checked, no obvious melting/wear
5. Accelerator pedal
- When the cable is out, pedal moves freely
6. Carb / pedal / cable sticking
- Individually, they move freely
Any tips?
Edited by classicoop, 10 May 2013 - 02:36 PM.
