I found some forum posts about getting past 2000rpm at it all goes poo. The pickup was found dirty, cleaned and all was well. But mine feels fine under load at 3500rpm and above. Still noticable the incorrect ignition.
I cleaned the sensor which was covered in oil, but it made no difference. I don't think oil on the sensor would make much difference as I believe it only detects the magnet on the flywheel to know what position the crank is in for the ignition.
The flywheel is the orginal, just the clutch and pressure plate were replaced. What about the magnet, can that be adjusted? Can the ECU be reset? Where's my Haynes manual when i need it!!! Anyone else to the rescue? Is it time for a trip to a rover dealer? :'(
