Battery Wrong Way Around!
46 replies to this topic
#1 paulfoel
paulfoel
  • 205 posts
Posted 09 May 2013 - 08:22 AM
Dont know how I did this but I did....
It even started. Then I noticed the smoke. Stopped engine quickly and whipped leads off battery....
Under the bonnet seems OK. Cant see anything.
Likely to be any damage? Anything that I can check.
I'm a little reluctant to reconnect the battery (the right way) just yet.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 09 May 2013 - 08:30 AM
Diodes possibly in the clocks and alternator, radio if you've got one!
The newer the car, the more potential damage!
What age is it?
Where was the smoke coming from?
Before reconnecting you need to see if you've melted any wires as they may catch fire when you reconnect
#3 petehuws
petehuws
  • 329 posts
Crumbs O_O what smoked?  Under the bonnet was the smoke?  Likely to be the starter that went puffing.....
Edited by petehuws, 09 May 2013 - 08:31 AM.
#4 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 09 May 2013 - 08:33 AM
The alternator might not of liked it
#5 paulfoel
paulfoel
  • 205 posts
Posted 09 May 2013 - 08:34 AM
Smoke from under bonnet. Its an old mini - 1996. jap import.
I'd have hoped that fuses would blow wouldnt they? How does the starter motor smoke?
Like I said weird how it actually started too.
I've opened the bonnet now and it doesnt look that bad. Cant see anything obvious.
Bit scared to connect it all up again for now.
#6 paulfoel
paulfoel
  • 205 posts
Posted 09 May 2013 - 08:38 AM
Would that smoke? Likely to be screwed now then? If thats all it is then I'll be semi-happy.
Thought the whole lot was going up!
#7 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 09 May 2013 - 08:40 AM
Doubt it would smoke but they don't like being wired up wrong so it could be fubared now
#8 samsfern
samsfern
  • 5,243 posts
Did the engine run backwards? :lol:
#9 petehuws
petehuws
  • 329 posts
Posted 09 May 2013 - 08:42 AM
Carlos is correct in giving the cables an eyeball for any damage but usually reversing the polarity shouldn't cause any cable, or loom damage.
Have you detected any blown fuses yet?
I'd quickly eyeball the cables, make a note of what fuses are blown, & what are good, & before diving in to replace the fuses I would then re-connect the battery 'correctly' then check around the car for bad smells, then one at a time replace the fuses starting with the most car critical i.e anything engine electrical, then lights down to least critical like radio, check that the new fuses hold out - cross fingers and start again.
You shouldn't cause any extra damage doing this, if there is damage then it has already been done.  Good luck.
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 09 May 2013 - 08:45 AM
Potential for a knackered ECU!
Fingers crossed that's not the case
#11 petehuws
petehuws
  • 329 posts
Posted 09 May 2013 - 08:55 AM
Damn yes, it's a 96 model O_O thinking about it the starter probably just turned in reverse hence the car firing and should be / could be OK, there's so many electronics then after this in an spi/mpi - not sure how is best to diagnose, but at some point I'd reconnect the battery to then find out; not sure how to check out the ECU apart from opening it up & looking for component damage.
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 May 2013 - 09:00 AM
Once your happy there is nothing burnt out, Reconnect the battery and just fit the terminal, the things that wont like a reverse polarity are Alternator-ECU-Radio, all the other stuff like starter motor will run backwards, its a case now of seeing if the fuses in the ECU blew or not or if its suffered more permanent damage.
#13 paulfoel
paulfoel
  • 205 posts
Sure its got an ECU? OK. Thinking about it it was imported in 1996 but its the old shape mini.
#14 paulfoel
paulfoel
  • 205 posts
Posted 09 May 2013 - 09:05 AM
Well, not brave enough to connect it up yet. That can wait until I've calmed down!
Opened the bonnet. Alternator looks ok but smells a 'little' strange not hugely.
How do I check if I have an ECU?
#15 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 09 May 2013 - 09:14 AM
If its a '96 you will have an Ecu. That is for certain. Whether its damaged or not is another thing
