1275 Unleaded Head On A 998.... Any Advantage?
Posted 07 May 2013 - 06:29 PM
Any wisdom is welcomed.
Posted 07 May 2013 - 06:34 PM
it has larger valves and better flow rate over a 998 head but you need to either pocket the block or sink the exhaust valves into the head otherwise valves and block faces and then you get a feces - fan interface.
you also have to work out the compression ratio with the different head and adjust as required :)
Posted 07 May 2013 - 06:40 PM
Good advice though, sounds like it would be a lot of modification to make it work properly.... might give it a miss.... Thanks for the info mate
Posted 07 May 2013 - 06:54 PM
Recessing the valves doesnt require the block to be stripped out the car to be pocketed either.
Posted 07 May 2013 - 07:08 PM
lot of people say its a very good option for a 998 and depending on cam you may not need do anything to the valve seats or block.
It is a measure before fitting job though to be sure of valve clearance and compression ratio
Posted 07 May 2013 - 09:05 PM
There is no point in having a cylinder head which has the capability to flow more fuel/air mixture unless the inlet & exhaust systems are suitable and the cam will provide the lift and valve timing to optimise the power.
Don't consider this unless you can do the measuring and calculations needed and understand the other modifications needed.
Posted 14 May 2013 - 08:42 PM
Slight thread revival,
But I just found a good pick of a 'pocketed' block. This is a 998 block prepared by MED to accept a 12g940 head (according to the poster on the forum i found it on). Thought I'd share
Posted 14 May 2013 - 08:57 PM
