Thanks for the information that is really helpful. What do you think about flipping it so its vertical on the back of my read seat? Should I still worry?
Vertical is good, just as long as there is a little air space above it.
Posted 09 May 2013 - 06:29 PM
Posted 09 May 2013 - 06:40 PM
I am gonna trial it where it is cause it was a ******* to mount it and would love to leave it up there but if it seems too hot after a drive I will probably move it to the seat back in the boot.
Posted 10 May 2013 - 12:06 AM
Day 4:
Still no fiberglass because I don't have the money for it yet. I installed my new door cards from Optimise Auto today. They are amazing quality and I am so excited with the look.
Posted 10 May 2013 - 02:48 AM
Edited by travellering, 10 May 2013 - 02:49 AM.
Posted 10 May 2013 - 12:01 PM
Nice Job - Keep up the good work!
- Take a break from the car - that grass needs to be mowed!
Posted 10 May 2013 - 02:13 PM
Haven't installed it yet, but I've measured out a piece of MDF for an amp mount under the parcel shelf, right way up, with the board under the amp, and two sets of l-brackets joined to make z shapes. One flat of the z is under the board, and then the brackets come up the sides of the board and mount to the underside of the parcel shelf. The two center holes of the parcel shelf will provide some room for cooling, and if that turns out insufficient, then a pcu fan will fit in the cutouts to actively draw cooler air over the amp..
This would still keep the back of the seat free, and prevent crap loaded in the boot from covering and overheating the amp
Thats a really good idea. I may have to try that. I may also just install two PSU fans while it is upside down since I alraedy mounted it. Then I will have some active cooling back there.
Thanks. Car's more important than the lawn plus it's my roommates turn!! Hahaha
Posted 11 May 2013 - 01:48 AM
Day 4!!
I finally got some fiberglass for the remainder of the subwoofer enclosure. I also set out to get my under seat headunit holder finished. Take a look!
Picture of the posts to hold the sub ring:
Guide for the Headunit holder:
Subwoofer ring mounted on there:
Fabric Wrapped over the sub Ring:
Another Shot of the Fabric:
Posted 11 May 2013 - 10:20 AM
Definately want to give this a go, Would you be able to keep a rough track of how much this has costed for the sub enclosure, Really want to give this a go!
Posted 11 May 2013 - 07:45 PM
Sure I will keep track for you!! I'll update you once I finish so you know how much it is.
Posted 11 May 2013 - 08:04 PM
Day 5!!
I woke up this morning early and got out to do a little more before I went out of town for the day. I got a second coat of fiberglass on the box and moved forward with the headunit holder.
Edited by SomethingNew71, 11 May 2013 - 08:04 PM.
Posted 13 May 2013 - 06:08 PM
Day 6 Final Day!!
I finally finished the box and got the sub installed this weekend!! I wrapped it with carpet however the carpet looks like **** so I will have to redo that. Hence why it isn't pictured. Otherwise the sub sounds awesome and my sound system is finally balanced throughout the whole car.
I will get some better pictures in the coming days!!
Posted 13 May 2013 - 06:30 PM
Changing songs on the motorways will be fun. Looks great though!
Posted 13 May 2013 - 06:34 PM
Luckily all of that is controlled on the iphone so I just do volume on the headunit. I don't have an antenna installed so I dont have radio.
Posted 23 May 2013 - 12:39 PM
box looks nice!!! Honestly, how hard is it to do?
Posted 23 May 2013 - 01:05 PM
Thanks!! I really wouldn't consider it hard to do at all. The hardest part was being patient. Fiberglass takes time to cure and become hard. Waiting for it to dry was the hardest part. Otherwise it was really quite easy.
Some things that would have made it even easier:
