Rivet the L bracket to the arch first, then your left with the arch and its 5 permanently fitted brackets. Then you can bend the L brackets to the angle of the car, drill the car and bolt the arch on using some small bolts from under the arch
not a bad shout to be honest, what rubber did you use?
thanks
