My Mini 1275Gt Rebuild Thread
228 replies to this topic
#61 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 09:10 PM
Does anyone know what goes over the hole with the two bolts on it?
Edited by Jase, 27 August 2013 - 09:11 PM.
#62 A-Cell
A-Cell
  • 1,610 posts
Posted 27 August 2013 - 09:42 PM
More expense I'm afraid....
Oil separator / breather
#63 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 10:45 PM
#64 Jase
Jase
  • 1,166 posts
Posted 06 September 2013 - 03:35 PM
Little update, haven't had time to do this recently. Engine peripherals fitted. I have a question perhaps someone could answer. I am fitting a new loom for a 78 car, however as you can see from the pic the starter is pre engaged. Is it easy to adapt the current loom? Also will it fit the alternator that I have on the engine? I can change the loom for a later if need be but I will need to run the three pod GT clocks.
Thanks for any advice.
#65 Jase
Jase
  • 1,166 posts
Posted 21 October 2013 - 09:57 PM
Final engine bits arrived yesterday, studs, new bolts for the starter etc. Verto arm, hoping to get the subframe and engine in place soon.
#66 malcs_miniturbo
malcs_miniturbo
  • 602 posts
Posted 29 October 2013 - 06:42 PM
this is looking great
#67 craig-721
craig-721
  • 166 posts
Posted 29 October 2013 - 06:54 PM
looking good very nice
#68 Jase
Jase
  • 1,166 posts
Posted 29 October 2013 - 09:14 PM
Thanks both, will have some more pics tomorrow night to add to these. 1/2 term is never a good time to work on the car:), hoping to finish the engine off this week.
#69 craig-721
craig-721
  • 166 posts
Posted 29 October 2013 - 09:20 PM
good luck with you engine
#70 Jase
Jase
  • 1,166 posts
Posted 05 November 2013 - 11:52 PM
Advice please. Have i put the verto plate and filter on correctly?
#71 A-Cell
A-Cell
  • 1,610 posts
Posted 18 November 2013 - 08:40 PM
Looks right. Verto slave bracket - So long as you also fitted the 1/4" UNF x 13/4" long bolt with a spacer underneath it as well, can't see it in the picture. This spacer is no longer available but the steady bar metal sleeve does the job (21A1108). Also ensure the top fixing bolts are'nt too long as they can foul the flywheel! (3/8"UNC x 1" long).
#72 Jase
Jase
  • 1,166 posts
Posted 22 December 2013 - 09:33 PM
Just thinking about the colour of the engine. It's a 1275 SPI engine which is red. Going in a 1275gt so I'm guessing I should paint it black or were they green?
#73 Laundrymike
Laundrymike
  • 27 posts
  • Local Club: Northern
Posted 22 December 2013 - 10:54 PM
I've a feeling they were painted black in 1275GT's...
#74 Fozz
Fozz
  • 145 posts
  • Location: Roeselare, near to Ypres (Westflanders, Belgium).
Posted 31 December 2013 - 11:38 AM
well, im also curious to know what the Original colour was for a 1275 GT engine...
is green a possibility???
#75 Jase
Jase
  • 1,166 posts
Posted 31 December 2013 - 11:53 AM
Green would be nice :) Traditional.
A few more pics of progress:
Gearbox/diff and manifold:
Rad and hoses in place:
Engine mount, copious amounts of copper grease on the back of the mount and everysurface. I'll clean the excess off before I put the engine in. I'm a bit wary of these fixed nuts, I'm going to cover in grease, may make it part of the service schedule and tighten and untighten every 3000miles.
Slave cyliner in place:
Front subframe together now. The bottom ball joint was a pain to get into the lower arm, all tightened up now:
upside down at the moment:
