My Mini 1275Gt Rebuild Thread
228 replies to this topic
#46 Jase
Jase
  • 1,166 posts
Posted 12 August 2013 - 06:53 PM
The best pic of the car so far, I will get more detailed ones soon:
Edited by Jase, 12 August 2013 - 06:54 PM.
#47 Jase
Jase
  • 1,166 posts
Posted 14 August 2013 - 05:13 PM
On two wheels now :)
Alleycats, looking sweet:
MOved back for crane access:
#48 Jase
Jase
  • 1,166 posts
Posted 21 August 2013 - 11:19 AM
A couple of slightly better quality pics:
Before Polishing:
After 1st cutting back, couldn't resist giving it a little buff, 2000 grit and then more buffing:
Edited by Jase, 21 August 2013 - 05:29 PM.
#49 [email protected]
[email protected]
  • 152 posts
Posted 21 August 2013 - 04:48 PM
Love this build :)
#50 Jase
Jase
  • 1,166 posts
Posted 21 August 2013 - 06:03 PM
Quick question (which I have posted elsewhere, sorry mods) Is it okay to use plastic ties on the driveshaft? I tried the metal clips but they are too loose even when tightened:
I just did some. Those look The CV joints supplied by Minispares. The clips are too big, will not go small enough. I went to a motor factor and got some bands that had more holes and would go tight. I think bands are better than cable ties. With your build worth the effort I reckon. "Don't spoil the ship for a ha'porth of tar! "
Looking really fantastic.
Bought new clips from the motor factors and a pair of carpenters nail cutters as seen on you tube. Worked a treat in crimping the clips.
#51 A-Cell
A-Cell
  • 1,610 posts
Posted 21 August 2013 - 08:50 PM
Great stuff. Glad you got it sorted. Coincidentally I went to Minispares today and advised them of he problem!
#52 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 05:13 PM
Some advice please, what is this for? Do I need to remove it?
#53 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 05:15 PM
Also slightly confused with these brackets and the slave cylinder. I've always been used to bolting straight to the clutch housing:
Edited by Jase, 27 August 2013 - 05:15 PM.
#54 A-Cell
A-Cell
  • 1,610 posts
Posted 27 August 2013 - 05:18 PM
It's the lower attachment for the ignition water shield. Personally I would fit a water shield, especially on the Clubman.
http://www.minispare...ck to catalogue
#55 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 05:23 PM
#56 A-Cell
A-Cell
  • 1,610 posts
That slave cylinder and bracket is for the Verto Clutch, post 1992. Short clutch lever arm. See Iluustrated Parts List
http://www.minispare...e.aspx?2~13~121
#57 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 05:26 PM
Thanks, so I'm guessing I will need this as well:
Never stops :)
#58 A-Cell
A-Cell
  • 1,610 posts
Posted 27 August 2013 - 05:33 PM
Never stops :)
Yes, if the clutch inside is a Verto type. What engine etc are you fitting. The A+ Engine was used on the last of the 1275 GT's, but with the Pre Verto clutch. The Verto clutch was introduced to Mini around 1992. All earlier A series engines were Pre Verto.
So these had the clutch slave in the position you are familiar with, bolted direct to the top of the flywheel housing and with a long clutch lever.
Hope this helps
#59 Jase
Jase
  • 1,166 posts
Posted 27 August 2013 - 05:44 PM
It's a new SPI engine from Minispares so I guess they have supplied correctly
Edited by Jase, 27 August 2013 - 06:02 PM.
#60 A-Cell
A-Cell
  • 1,610 posts
Posted 27 August 2013 - 05:58 PM
Ah, ok. Well then it is a Verto clutch, so you will need the lever. That's why the bracket is on the front for the ignition splash shield.
It will be worth it in the end!
