Hi all,
I'm after some opinions on CV joints. I had a brand new CV joint and bearing fitted on the front drivers side approximately 2 months ago.
This morning with the steering wheel turned I noticed an ever so slight clicking noise coming from the front driver side wheel.
Past experience tells me this is a CV joint failure. I don't know why I'm going through CV joints at such a high rate. Here's the history of what components I've been through in the past year on the front drivers side wheel assembly
Bought car 15 months ago (March time)
A few days after purchasing I had the wheel bearing replaced
Last October, noticed horrible grinding noise and wobbly wheel.
Wheel bearing had failed again in spectacular fashion damaging the CV joint in the process
New wheel bearing fitted
Reconditioned CV joint fitted (I couldn't get hold of a new one at the time)
March time this year - more grinding and clicking noise
Inspection showed CV boot had failed letting in debris again damaging the CV joint
Brand new CV joint fitted
New bearing fitted for good measure
This morning - more clicky CV noises :-(
I asked the previous garage (a mini specialist) to check out the hub when the last CV/bearing was replaced, just in case there was something else going on causing all these problems but everything seemed ok.
Has anyone got any ideas why I am going through these components at such a high rate. The car is not a high mileage car. I've done approx 3000 miles in just over a year. Apart from the recon CV joint I have purchased good quality parts from mini spares (including Timken bearings). This thing is going to bankrupt me soon.
Thanks in advance for any thoughts
