If you only run about town in your Mini then it's probably fine for a while on unleaded. But if you use motorways then you must use an additive. Castrol Valvemaster Plus seems to be the one to use.
Even LRP petrol was pretty useless on mtorway runs. I had exhaust valve problems within 1000 motorway miles. Compared to no problems at all using the same engine with a replacement leaded head running on unleaded petrol and valvemaster plus.
inline lead additive device
starrider
, Apr 24 2006 08:11 PM
18 replies to this topic
#16
Posted 25 April 2006 - 11:02 AM
#17
Posted 25 April 2006 - 01:07 PM
i will deffinately take the advise. i have a bottle of the valvemaster which i use in my '81 and will start using it in my clubby.
#18
Posted 25 April 2006 - 04:39 PM
Undoubtedly thee devices have a benefit over using unleaded with no addatives.
No they don't, it is the same as using unleaded with no additive. And as for being anyone's guess, there's no guessing involved. It's not just 'some lead' that gets put into petrol which will wash off the surface of a chunk of lead as the petrol flows over it. It's a very specific compound (Tatra-Ethyl Lead) at exactly the correct doseage. There's been lots and lots of testing done over the years, devices which claim to infinitely add lead to your fuel don't work. It's a con.
LRP is the only completely unregulated fuel in the country. There is no standard for it to meet and it really could be anything in there, usually it's junk. No good for protecting your engine and not a lot of good for running it either.
Real 4 star is still available from a select few outlets. It is produced in small batches by Bayford fuels, check their website to find out where you can buy some.
Bayford Thrust
#19
Posted 25 April 2006 - 05:43 PM
Iv taken an engine out of a mini that had an 'ECO GREEN' contanor in the fuel line. i think its that sort of thing.
