* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#1381 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 September 2015 - 11:36 PM
Best of luck! I really hate moving!!
Me too but it's a move that we desperately need so we are looking forward too it :-)
Ben
#1382 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 02 September 2015 - 06:13 PM
Good luck with the move, you will be back on the panels in no time!
#1383 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 September 2015 - 06:19 PM
Cheers.
Hopefully it won't be too long but with nowhere there to work on it, i't going to take some doing to get it in the back garden with no side access.
where there is a will, there is a way and all that.
Ben
#1384 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 September 2015 - 07:57 PM
Garage is packed..
It's amazing how much room there is with all the crap thrown away and all tidied up
#1385 CBJ805T
CBJ805T
  • 438 posts
Posted 03 September 2015 - 04:20 PM
SITREP:
The boot lid fit is still terrible. I can't get enough adjustment to make it look even half sensible. It seems to be since i fitted a different hinge. They are the correct sides so i know it's not that.
Then i was fed up with the mess everywhere so put the Mini outside and spent 2 hours tidying up. I also cleared all the crap out of the Mini.
Ben
Hi Ben,
Sorry to hear you're hanging up the welder for a while. before you do I had a question about welding the rear bulkhead to the boot floor. How did clamp / hold the two panels together as you plug welded them?
tacking this job in the next week or so, so just wanted some tips.
#1386 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 September 2015 - 04:31 PM
SITREP:
Ben
Hi Ben,
It all depends really.
Mine had a slight gap between the bulkhead bottom flange and the seat base so i had to chase it down tight with a wide bolster and a hammer to tighten the gap.
As long as the flange sits naturally close to the floor, you can just use the shaft of your hammer to hold it tight next to each plug weld hole as you go along.
I often use that method and it works well providing nothing is under tension.
make sure its a hammer with a wooden shaft though
#1387 CBJ805T
CBJ805T
  • 438 posts
Posted 04 September 2015 - 11:59 AM
thanks for the tips!!
#1388 James_eaton_thewholething
  • 1,063 posts
Posted 04 September 2015 - 06:43 PM
Ben quick question. Any where that you have taken back to bare metal that had surface rust what did you use to treat the metal and has the rust stayed away ?. I'm just concerned about parts of my bulk head that's all
#1389 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2015 - 05:13 AM
I made sure that first every trace was removed and then i used a Zinc rich primer. I have it on good authority that the zinc content sacrifices itself to neutralize any remaining traces of rust in the steel and so far after a few years, it is completely rust free still.
Time will tell in the coming weeks/months after it has been stored outside
Ben
#1390 James_eaton_thewholething
  • 1,063 posts
Posted 05 September 2015 - 06:50 AM
Ben
Cheers for reply Ben. that's what I'm trying to do with really decent wire wheels in the angle grinder plus some kurust so I can see where there is still rust, then using zinc rich primer on top should hopefully be ok then. Sucks that you have to store it out side but I'm sure it will hold up if it has already so far
#1391 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2015 - 08:05 AM
Ben
you shouldn't need kurust and zinc primer but i suppose it wouldn't hurt.
have you tried filament brushes?
#1392 James_eaton_thewholething
  • 1,063 posts
Posted 05 September 2015 - 10:06 AM
I haven't tried filament brushes I will look into getting some and giving that a go. Anything decent to get panels to bare metal quick or is everything slow ? Just that is more annoying and time consuming than drilling holes
#1393 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2015 - 10:10 AM
These http://www.ebay.co.u...=item1c22f67d45
And these http://www.ebay.co.u...=item1a01f456e1
use them carefully as they get quite hot but they rip paint off quickly
See for yourself
#1394 James_eaton_thewholething
  • 1,063 posts
Posted 05 September 2015 - 10:25 AM
Will be getting some of those wheels I've used them before and liked them.
2C92B360-BFAF-42B0-A32B-A8419B3A1A4C_zps
Is this what you meant by the filament brushes ?
#1395 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2015 - 10:27 AM
The filament cup brush in your picture is USELESS.
Get this one
http://www.ebay.co.u...=item5d5c8547f1
