* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#1366 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 August 2015 - 05:25 PM
Great work on the arches! Mine have two largish holes in the top on both sides, is it easier to remove the whole arch rather than mess around with fixing a very inaccesible hole?
Q
It is much easier but the panel is quite expensive
Lovely work as always ben !
thank you :-)
Filler? What's filler?
I said filler-less  :P
#1367 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 August 2015 - 05:38 PM
back to the roof repairs today.
First up was to weld the seam in the gutter, grind it back and then re-shape the gutter back to how it was before i bent it out of the way to do the repair.
Ill just let the pictures do the talking, it's been a long day...
I'm calling that finished.. I can't be arsed to work it anymore.
and then some surgery on the n/s front corner. same sort of thing as the other repair, again, the pictures can speak for themselves
I scraped the sealer off and there was no paint at all underneath, not even primer. no wonder the rusted so much
it got late, so i left it there. still some grinding and tidying to do before bending the gutter back into shape.
More tomorrow....
Ben
#1368 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 31 August 2015 - 06:11 PM
Looking great as always ben, great repairs, need to get cracking with myn =).
Mark.
#1369 peterjh
peterjh
  • 24 posts
Posted 31 August 2015 - 09:23 PM
nice work, good recovery ! Glad you did post that it gives a good insight into how its done.
#1370 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 August 2015 - 09:26 PM
Cheers, it got there in the end
Ben
#1371 peterjh
peterjh
  • 24 posts
Posted 31 August 2015 - 09:31 PM
is it a roof panel you are cutting the repair pieces from ?
#1372 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 August 2015 - 09:37 PM
Some old roof corners that i bought off of another member ages ago.
The roof corners were cut from the donor shell and included the windscreen frame/cant rail and all of the inner frame work and a good few inches of the pillars. when i repaired the drivers side front corner using one of the pieces, i made the mistake of cutting and shutting the whole piece including all the bits of post and frame.
I would not recommend that method unless those areas are rotten. It's much easier to just seperate the roof skin from the donor section and fit just that as i have done on the last two repairs.
Ben
#1373 peterjh
peterjh
  • 24 posts
Posted 31 August 2015 - 09:43 PM
well from the photos you have posted it certainly looks like the best way to do it. Good to know .
#1374 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 01 September 2015 - 07:19 AM
Awesome roof repairs. I'll be using your method as I got at least one to do on my GT.
#1375 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 September 2015 - 08:47 AM
Thank you guys  :proud:
#1376 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 September 2015 - 04:04 PM
Sadly, this will be the last update for a while. Maybe until next year now :(
All i have to show for today is a finished roof repair
And after a whole day of packing up the garage ready for moving, i put all of the panels i have into the shell.
I actually feel quite sad..
The next challenge is to get all of this into 2 medium sized sheds (apart from the bench, fridge freezer and server cabinet)
I've chucked loads away but still might need the help of Mary poppins :lol:
Thanks for looking.
Ben
#1377 James_eaton_thewholething
  • 1,063 posts
Posted 01 September 2015 - 06:41 PM
All the best with the move Ben. Your work is as awesome as ever on that roof panel. I'm sure you will manage to get all that stuff into the two sheds. Will be waiting for an update in the near future
#1378 Covert
Covert
  • 526 posts
Posted 01 September 2015 - 06:51 PM
Good luck with the move ben, hope you get on ok .
#1379 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 September 2015 - 08:08 PM
thanks guys
#1380 mini_matt_106
mini_matt_106
  • 591 posts
Posted 01 September 2015 - 11:00 PM
Best of luck! I really hate moving!!
