Today was a day of mixed feelings. started off ok and ended on a bitter note...
I started by trimming the bumper lip a touch as described in the last update.
Looking better
Then i put the subframe back in just to make sure everything was ok. it went straight in with no fuss.
Next before bolting up the rear trunions to the boot floor, i needed to prep the reinforcers for welding.
You can see in the above picture that the bottom of the quarter panel is a terrible fit and i was never happy with that repair so i shall re-do it in a few days.
Got the other side prepped too
It was just a case of drilling some 6mm holes in them to plug weld to the floor, cleaning back and priming. I also bare metaled the adjacent areas on the boor floor and arch tub.
And here they are bolted in place
Took a fair bit of juggling around to get the bolt holes lined up well with each other.
Once i was happy,i went around the whole area to check and double check everything fitted well and then made a start plug welding the bumper lips together.
I just put a couple of clamps between each ole and moved them as i went.
Then plug welded
and linished back
Then i put the bumper on to see how it fitted. It seemed to line up perfectly well with the holes.
It is reasonable uniform but can be tweaked later.
Next job was to plug weld the arch tub to the boot floor
Then weld in the reinforcers
Clean up the plug welds and prime
You might also notice that i put some seam welds inside the boot between the arch tub and floor just for a bit extra strength
And then the seat belt mounts
Then put the bootlid on.
But i dropped the sodding thing.
Luckily i managed to find another hinge but now the fit is horrendous. Uneven gaps and the damn bumper now won't fit past the hinges.
i don't know what i am going to do??
This side is miles out
and the other side WORSE
This isn't helping
I can't move the hinge up any more so i'm stuck...
I did think about taking the grinder to the hinge. Is that a good idea??
Ben
