* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#1246 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 19 August 2015 - 10:30 PM
looks good ben. i had the same issue with the boot floor not lining up but mine is due to using a pattern repair panel and not the whole floor panel lol. glad the boot lip lined up everything will be in, in no time what so ever
Cheers.
I was going to do more today but i struggled so much to get the subframe in on my own that i couldn't get the momentum to take it back off again.
Ill try and get a couple of hours on it tomorrow afternoon and get the floor out and prepped
#1247 James_eaton_thewholething
  • 1,063 posts
Posted 20 August 2015 - 09:10 AM
Rear subframes are a real pain part of the reason I'm going to coilovers. Plus mine is so badly rusted through that would need to get a second hand one. At least you know now it lines up
#1248 mini_matt_106
mini_matt_106
  • 591 posts
Posted 20 August 2015 - 09:26 AM
Ps. What gas are you using/would recommend?
Thankyou for the kind words mate.
I am using hobbyweld argon/c02 mix. As far as i can remember, it is a £50 refundable deposit for the bottle and then about £36 for a refil. You also need to get a regulator and conversion hose which costs up to £50 depending on what you get.
i can show you the regulator and hose i have if it helps.
Ben
That would be great if you could, I think I remember seeing it on your trolly build pictures (great idea by the way, totally building one!) are they the bottles you can get on eBay?
#1249 mini_matt_106
mini_matt_106
  • 591 posts
Posted 20 August 2015 - 09:30 AM
Also, I watched a mini resto vid on YouTube last night and it looked shocking compared to the standard you work to! Filler everywhere!
#1250 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 10:36 AM
I was watching another mini25 on ebay for sale and they had it as a classified ad but it was unfinished and they disclosed that it would be available once completed.
The pictures they put on eBay of the work in progress were a bit like that..
#1251 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 10:39 AM
Ben
This is the regulator
http://www.ebay.co.u...=item487c467c13
And this is the conversion pipe
http://www.ebay.co.u...=item23530da906
I get my gas from these guys http://www.hobbyweld.../find-an-agent/ Just put in your postcode and it will tell you the nearest stockist. Mine is a local builders merchant
#1252 mini_matt_106
mini_matt_106
  • 591 posts
Posted 20 August 2015 - 11:52 AM
Thanks, looks like pretty cheap stuff but if it does the job then I'll go for it! The nearest stockist to me is 15miles away, I know I can get similar stuff locally but it's expensive. Cheaper than having to get a pay monthly bottle of argoshield though!
Keep at it! Are you trying to get the panel work sorted before having to transport it? Then just tidying up welds after the move?
#1253 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 12:25 PM
It all works perfectly so can't grumble really.
For gas, try Adams gas. same sort of deal and they might have a nearer stockist?
I want to get the boot floor in, the n/s rear arch tub replaced and then hopefully the inner sill and quarter panel on the n/s.
Just over 2 weeks to go....
I'm right in the middle of prepping the boot floor now
#1254 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 06:26 PM
It's been a very long afternoon but i am finally moving closer to a major milestone in the build.
Before i could progress,i needed to take the Subframe back out and the boot floor too.
Then i remembered i hadn't ordered any drill bits. so i took a walk round to Hurst's to see what they had. i only really needed a 6mm bit but at almost a fiver for one drill bit, i decided to go for this instead
nice draper ones, a bargain thought I. Then I noticed that the sticker on the tin was a bit peeled so i tore it back a bit and found this
cheeky buggers. i was in two minds whether or not to take it back but i thought i would give them a try. They are really good so will be staying.
Anyway, The first thing was to remove the battery earth clamp set nut from the old floor.
The new floor doesn't come with one so I carefully removed it, cleaned it up and zinc sprayed it
Whilst that dried, I made up a template for the fuel line hole in the floor to convert to the earlier single line type
And welded it it
I just need to drill the hole for the single fuel line now but at that point i was waiting for measurements from Neil before i could drill. (Thanks Neil for those)
In the mean time, i welded in the earth clamp captive nut holder thing
Next, I made up a few of these.
which go here
a splash of Zinc
Whilst that dried, i decided to drill the bumper holes in the new bumper lip i made. Before i dropped the floor out, i marked the position with a marker pen so all i needed to do was drill up from underneath with a small drill bit
Then a slightly bigger one
then the step cutter to the correct size
I did all three.
Then i drilled a load of 6mm holes every 20mm
probably a bit over kill but never mind.
Then i received the measurements for the fuel line hole so measured and drilled that
and that's the floor ready
Next i drilled the holes for plug welding on the lower rear bulkhead
Marked out
and drilled
Then it was time to put the boot floor back in
and in
secured with bolts through the bumper holes
After a bit of tweaking,it was fitting well but i noticed that i need to trim the bumper lip i made for the rear panel a bit one side
So marked it out
And ill trim it tomorrow.
it is important to have the 3 layers (bootfloor, back panel, rear valance) stepped so that you can get paint and sealer in. If they were all flush with one another, it would be difficult to seal the edges and water would creep in there in no time at all and rust it all out again.
Tomorrow, ill need to re-fit the subframe to check alignment again and then weld it all in.
A question for you though, How many wiring tabs should there be along the back edge of the boot floor? I have installed 5 and their location was determined by square dimples pressed into the back edge of the floor but there was only 5. it seems to me that there should perhaps be another on the left of this picture?? (blue square)
would someone be able to check please?
Ben
#1255 Carlos W
Carlos W
  • 10,114 posts
Posted 20 August 2015 - 06:30 PM
I can't believe how much of the rear of the mini you have recycled.
I'm truly amazed
#1256 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 06:32 PM
I'm truly amazed
Waste not, want not  ;D
Whatever that means??  O_O
Cheers!
#1257 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 20 August 2015 - 07:47 PM
I can go out and check now at my boot tabs if you want?
#1258 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 08:21 PM
If it's ok mate?
that would be lovely
#1259 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 20 August 2015 - 08:31 PM
Wow! Fantastic work Ben. You make it all look so clean and easy. You're too good :P
#1260 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,785 posts
Posted 20 August 2015 - 09:06 PM
I wouldn't go that far mate!
it is all straightforward stuff really, just time consuming and the clock is ticking..
Ben
