* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#1201 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 August 2015 - 12:42 AM
I dream of days this productive!
The repair on the rear panel is great - I have that exact job to look forward to once I source a replacement.
I should have sourced either a better one or a new one as this one does need alot of work but i like the challenge and it's perfect where it counts. Just that bumper seam to contend with.
#1202 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 August 2015 - 05:57 AM
Yeah, always happens with me too haha. 1 can of primer for £8 in there... or 12 cans of better stuff for £30 on ebay.
Got a link?
Ben, your pics are really helping me with removing old inner and outer sills etc. So thank you! :)
#1203 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 August 2015 - 09:30 AM
Got a link?
Excellent!
I shall be doing the other side very soon too
#1204 James_eaton_thewholething
  • 1,063 posts
Posted 11 August 2015 - 12:28 PM
Your updates are always good, shows that everything is possible and makes me know that all of my repairs are possible with just a bit of time and patience. I've got the boot hinge panel to replace soon and this has helped me see how it's done
#1205 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 12 August 2015 - 04:29 PM
Got a link?
I've been using 'red oxide' (obviously no different to any other primer now because you can't get proper red oxide) purely because I started using a few cans I had at home, and then I wanted the rest to match.. But i'm pretty sure they do grey primer too.
http://www.ebay.co.u...=item43e01183f9
I used autotec acid etch primer back when I did my mini, and also paid about £30 for 12 cans. I'm not sure why I keep buying aerosols as I have a compressor and all the paint equipment.. oh well.
#1206 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 August 2015 - 04:57 PM
Got a link?
Just to add, i always recommend using a zinc rich primer or weld thru primer on flanges prior to welding. It's also good in enclosed places like between the inner and outer sills for example.
It will help prevent rust forming in the seams
#1207 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 August 2015 - 02:15 PM
The rest of the boot floor is out and almost ready to take the new one.
Speaking of which, it has now been ordered along with some other goodies.
update to follow when i get time......
Ben
#1208 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 August 2015 - 03:58 PM
Back on with removing the remnants of the boot floor.
although the arch tub is being replaced, i need to keep it intact and in shape to line the new boot floor up to so i need to do it carefully.
Clean off the sealant to reveal the spot welds
First bit off
Bit more
Then drill the spot welds from the rear bulkhead to the boot floor
then split it and carefully peel it away
A bit more
And that's that chunk off
All gone
I need to keep this part as it has a reinforcer that runs along the front of the seat base so will need to go in after the new boot floor is fitted.
So i cut it off and put it to one side
Then i removed the remains of the side of the seat base where it welds to the companion bins
I couldn't get any flap discs so i got a pack of these
Which are ok...
Then clean back the rust and remains of the spot welds
So that's it all gone
I also put some weld thru primer over the bare bits inside
I still have quite a bit of tidying up to do before the floor can go in but this little lot alone took hours and hours  :ohno:
In addition, i need to make up a new bottom to the rear bulkhead as it is shot to bits.
More tomorrow......
#1209 Rocket.
Rocket.
  • 1,444 posts
Posted 14 August 2015 - 09:40 PM
Haven't looked at this in a while
Great work as always !
#1210 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 August 2015 - 04:25 PM
I got a bit more done today but not a scratch on what i had planned.
I need to get the lower rear bulkhead repaired before i can fit the new boot floor so i started by cutting out one of the rust ridden areas and made up a new piece.
here it is clamped in
And welded
Obviously once the repairs are finished, i will trim the repaired sections to the correct size. The reason for the oversized repairs is that i can weld the sections together on the edges further than it needs to be and then trim up to get a nice neat edge instead of blown edges. We all know what a pain it is welding to an edge.
I ground down the back side inside the boot but then whilst changing discs on the grinder, the spindle lock decided it didn't want to lock the spindle anymore...
so here is a very warm welcome to Grinder number 4
I also cleaned back the sealer from the floor to heelboard join
The reason i only did basically sod all is because i had to mess around taking the grinder back and waiting for the replacement and by the time that was sorted, i couldn't be bothered.
Ill try and get a full day tomorrow
Ben
#1211 Covert
Covert
  • 526 posts
Posted 15 August 2015 - 09:05 PM
Looking good ben lots of progress since i lasted visited, keep the pics and updates coming .
All the best Mark.
#1212 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 August 2015 - 05:31 AM
All the best Mark.
Cheers Mark.
#1213 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 August 2015 - 04:44 PM
All afternoon i have been slogging away and don't really have much to show for it.
The rear bulkhead repairs took much longer than anticipated due to the bottom being more corroded than i first thought.
Never mind...
First things first was to get this repair piece made
Which goes here.
Again, it is oversized so that it can be trimmed with the other part.
Here it is welded in
And then ground down and trimmed
the other side needed a bit too
Same process and here it is welded in
then i found this bit which i must have done when cutting the boot floor out. it's obviously from a cutting disc
So i made up a piece and welded that in
You can also see the other piece in that shot ground up and trimmed
next, i got on my back under the car and ground the welds back some underneath where they will be seen inside the boot. I left them slightly proud for strength but will need to revisit that area later down the line so that they are not visible on the finished car.
Here is a common thing on my shell and i'm sure many others
A slight rust trail which you might almost miss if you weren't really looking. My shell is covered in them, especially inside..
If you give it a very quick brush over, it's clear how far they spread
and another
And there are dozens more on the rear bulkhead alone. I shall end up stripping the whole panel back to make sure
anyway, the finished rear bulkhead repairs in some zinc spray
I can't believe how long it took and i had so much more planned but at least it;s a horrible job ticked off the list. it does me in keep clambering in and out of the shell
until tomorrow...
#1214 James_eaton_thewholething
  • 1,063 posts
Posted 16 August 2015 - 05:19 PM
Looks good Ben. It's definitely moving along now at a good pace cannot wait to see this finished
#1215 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 August 2015 - 05:20 PM
Me too mate.
I just wish i wasn't having to rush it along currently because i am having to leave all the finishing until later where as i usually like to do it as i go.
It will be ok in the end though
Cheeers
Ben
