A little bit more done today. Not as much as i had hoped because i started late and everything took much longer than i was expecting.
So carrying on from yesterday, i started by cleaning back the welds on the back panel. I used a combination of a flap disc, 1mm cutting disc (to get in the tight corners) and a normal grinding stone.
Here is one side cleaned up
I was slightly disappointed with the join between the side of the lamp hole and the external body seam but i will be cutting the external seam part off of the repair section of back panel and adding in a new piece as it's quite misshapen.
Not to worry.
I then decided to take a look at some rust on the lip where the rubber sits just to see how far it went.
As this is on a folded/rolled edge, i am going to have to unpick it all at some stage and clean it all up properly but for now, i just cleaned up what i can see and it looks ok.
With that done, i cleaned back a bit more of the red paint from this side and then toshed some Zinc over it
Then i did the same on the other corner.
I also needed to weld the external seams together between the back panel and the quarter panel at the bottom so that was a case of clamping everything up tight and then using a piece of flat copper plate clamped to the edge so as to stop the edges blowing
This is the bottom part
It looks really messy but i have got plenty of material there to shape up to form the correct curve to the external seam.
For anyone interested, this is how i did it. In the pictures, i was adding weld to the edge of the seam further up as it was a bit wobbly where i had gone a bit too far with the flap wheel when shaping it before.
I just used a marked pen to show me where i needed to add metal and clamped the copper in place
Then add weld to the edge
Then remove the copper
Then grind flat the faces of the seam both sides
And then carefully dress the edge to blend to the correct profile
And that is where i left i today
Ben
