Not much really to report today. I needed to give the garage a clear out so the Mini got to sit on the driveway and catch some rays. First time it's been out of the garage for about a year i think.
Whilst it was out on the drive, i had another play with the panel fit down the drivers side. I needed to sort out the way the Apex panel fits to the front edge of the door. as you can see a few posts back, the door in it's natural position sits to far back from the apex panel.
I took the door back off and using a couple of blocks of wood and a G clamp i managed to get the apex panel to come in just enough to more or less solve the problem
Then i used a small G clamp to pull the bottom of the Apex panel arch lip in line with the one on the step.
Here is how i have got it so far.
All that seems to be wrong now is that the door still sits slightly back from the Apex panel but having a good look and feel of the door and all it's horrible prior repairs, the front edge seems to bend in slightly so i am sure that when the new skin goes on, it will all be spot on.
The overall gaps are starting to get there now although i need to have a play with the quarter panel when it comes to welding it on as this edit shows
Beside the red line, the door sits proud of the quarter panel so when it comes to weld it, i can bring the front edge of the quarter out slightly to meet the door perfectly/
Beside the yellow line, the quarter panel sits slightly proud of the door so i shall push on the quarter panel to move it in slightly before welding.
The rest of the door lines up perfectly with the quarter panel apart from the very top where obviously it currently is sitting on top of the remains of the old quarter.
So overall the gaps are starting to come together now. Ill leave them alone now until i reskin the door.
I put the other door on too just to compare how the window frame fits against the a post. The passenger side door is a perfect fit where as the drivers side sits in slightly to the a post so i have a plan of how to sort that but not until i get the old door skin off.
The rest of the pictures are just general shots of it out on the drive.
Ben
