* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#946 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 May 2015 - 04:36 PM
I tried to get a photo of it but it's almost impossible with the door on.
the gap available is between the two red lines (well actually it's not that wide but the photo is too overexposed to see exactly)
Should pull over a treat i hope
#947 Carlos W
Carlos W
  • 10,114 posts
Posted 06 May 2015 - 04:37 PM
Use a torch and switch the flash off mate
#948 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 May 2015 - 04:43 PM
I might just take the door off again, i think ill end up needing 1 shim on the top hinge after all now i have had another look.
BOOOOOOO!!
#949 Stu.
Stu.
  • 912 posts
Posted 06 May 2015 - 07:31 PM
Oh no, not the shim of shame :ohno:
#950 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 May 2015 - 08:58 PM
ha ha, i wanted to see if i could build a Mini that didn't need door shims and i have failed :(
#951 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 06 May 2015 - 09:00 PM
"Ben, you have failed this mini"  >>-------------> (Said in the voice of the green arrow) :P
Edited by Vinay-RS, 06 May 2015 - 09:00 PM.
#952 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 May 2015 - 09:02 PM
Ill see what happens when i re-skin the door, all may not be lost :lol:
#953 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 May 2015 - 03:33 PM
Received these today
I don't need them yet but my original callipers are beyond repair (heavy corrosion on the mating faces of the two halves) and my original back plates were full of holes.
I don't really need the disks or drive flanges but i may use the flanges as they are in better shape than mine.
They should look great once refurbished. i am considering having the callipers plated instead of painted for originality's sake
Ben
#954 Covert
Covert
  • 526 posts
Posted 07 May 2015 - 04:00 PM
Mmmm plating
#955 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 08 May 2015 - 09:54 AM
Ben, when did they switch over to discs on all minis in the UK?
#956 Carlos W
Carlos W
  • 10,114 posts
Posted 08 May 2015 - 10:05 AM
1984 I think, same time as going to 12 inch wheels
#957 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 08 May 2015 - 10:44 AM
Nice, so literally just after they stopped production over here...
#958 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 May 2015 - 11:19 AM
Yup, the 25 was the first to have them fitted as far as i am aware
#959 alchall
alchall
  • Just Joined
  • 604 posts
Posted 08 May 2015 - 12:41 PM
Hi Ben,
Which filament cup / brush / sticks would you recommend? not sure which one you are saying is useless, but I'm thinking of getting myself some
Also, just wondered if you ever found that spare spot tip dresser - if so, send me a PM if you would be interested in selling it?
Chris
Hi Chris.
I started off by buying the 100mm flat brushes which are excellent
http://www.ebay.co.u...=item27c84efa57
Then i bought this set
http://www.ebay.co.u...=item43ad3b0971
But the cup brush and end brush don virtually nothing so i wouldn't buy that set again although the free set of wire brushes were very good.
The flap brush was ok but not as effective as the flat one either
Just stick to the flat 100mm ones, they are great.
Ill PM you about the tip cutter
Ben
How quickly do you get through these things? thinking I will order some but not sure how many to go for....
#960 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 08 May 2015 - 01:42 PM
Great work on this! nice to see someone fabricating parts and taking care to fit neatly and make to look like
original.I have just joined this forum and came on your build.Last owned a mini 40yrs ago seriously  thinking
of starting to restore one (hard to find) need to teach grandsons and pass on my know how, been retired for
a couple of years after 51yrs in body/shop car and truck repair business .
Keep up the good work
Frank
