* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#856 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 April 2015 - 04:14 PM
Anyway, it's looking great Ben. I can't wait to see it finished
Cheers, and me neither
#857 Covert
Covert
  • 526 posts
Posted 12 April 2015 - 05:00 PM
Ben what size hole are you drilling to plug weld ?
#858 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 April 2015 - 05:01 PM
6mm mate
#859 Covert
Covert
  • 526 posts
Posted 12 April 2015 - 05:05 PM
Thanks very much !
#860 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 April 2015 - 05:07 PM
No worries
Thanks very much !
#861 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 13 April 2015 - 07:06 AM
Great tutorial for the inner wings as I'll soon be doing this when my bits arrive.
Ger
#862 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 April 2015 - 08:49 AM
Ger
If you need any pointers, give me a shout :-)
#863 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 April 2015 - 06:25 PM
I thought i had better start grinding down those plug welds. I was going to leave it for a while because it's the most exhausting job on the car but i got it down.
After 40 mins, i was half way through
And then a little while later, i had it all done and cleaned up.
And after a go over with the filament brush to feather all the edges
Next job was to weld up all of the unwanted holes in the inner wing. I marked them out with masking tape comparing it with the old one. The blue circle on one of the bits of tape is to tell me that the hole beside it needs making bigger to match the old panel.
Here they are welded up. I just filled the holes with weld rather than weld in bits of steel.
No amount of weld would fill the big hole so i made up a metal disk to weld in
And as if by magic
And there is the hole i had to open up a bit
Next, i turned my attention to the brackets that fit to the inside of the inner wing for the washer bottle and bonnet prop.
Here is the old rusty bonnet prop bracket
I didn't take a picture of the washer bottle bracket but it was a mess. Someone has previously fitted a piece of inner wing and just roughly bodged the brackets back on.
I could have re-used it but i had this in my box of tricks
Its off of that SPI shell i cut up and it's in much better condition.
So i split it from the old bit of metal
Then cleaned it up, zinc primed it and clamped it in place using the old panel to measure from. I also zinc primed the area of inner wing behind it
Then welded it and cleaned it up
And then i tried on the washer bottle
next was the bonnet prop bracket.
I split it from the old inner wing
it looks too far gone but it's still plenty thick enough and cleaned up fine
here it is cleaned up and welded on
Then i cleaned the whole area up and gave it a coat of Zinc. I lashed it on round the brackets so it would creep under the brackets where it will have burnt off during welding.
Tomorrow, ill make up some new wiring tags to go on it and then it's about done.
I also got this the other day
Its an old server tower. i got rid of the server racking and made some shelves instead. It's really handy and it's on castors too so can be moved around.
Oh, and it was FREE!!!
Ben
Edited by Ben_O, 13 April 2015 - 06:30 PM.
#864 Tupers
Tupers
  • 4,142 posts
Posted 13 April 2015 - 06:28 PM
Exceptionally tidy work there Ben, give yourself a pat on the back.  :highfive:
#865 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 April 2015 - 06:31 PM
I would if it didn't hurt so much  :wacko:
Cheers though, means alot!
Ben
#866 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 13 April 2015 - 06:53 PM
Awesome work and great free storage!  Always looks and smells better when it's free
#867 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 April 2015 - 06:55 PM
Cheers!
yeah, i was surprised when it came up in the local classifieds. i stumbled across it looking for something else. The bloke who had it only lives round the corner too
#868 Hendred
Hendred
  • 484 posts
Posted 13 April 2015 - 07:18 PM
Result!
#869 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 13 April 2015 - 07:28 PM
Impressive work
#870 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 13 April 2015 - 07:55 PM
I'll say it again, the level of detail and thinking going into this is superb.
