* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#796 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 March 2015 - 03:46 PM
I have just had another play with the inner wing. I started by chopping the bottom bit off.
Which has allowed me to move the flitch in more
But it still needs to go over as you can see by me holding the A panel in place
I'm not sure if it needs to go in or if the sill/step needs to come out or both??
I took this measurement from seal lip to seal lip. Can anyone confirm that it's right please?
Ben
#797 Petrol
Petrol
  • 967 posts
Posted 22 March 2015 - 04:05 PM
Mine is exactly 50" Ben
Pete
#798 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 March 2015 - 04:11 PM
Pete
Ah so it's pretty damn close for a guess!
That means that the inner wing has got to go over more.
That's excellent!
Thanks Pete.
Ben
#799 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 March 2015 - 01:38 PM
I decided i'm finally going to weld on the hinge post today but i needed to build it up more times to be certain i was happy with the positioning.
I started by putting the hinge post, inner wing and door back on along with the Apex panel to gauge the door height and position.
Hinge holes all lined up
And door on
This gap is a tad wide so i will have to attend to that later
This one is ok though. pretty close anyway. I might reduce it slightly later
So happy with that, i screwed the inner wing to the hinge post to keep it all in place and removed the panels.
Then i popped a plug weld in the top
And then one in the bottom
Followed by a slug here
Then i built it all up again to check everything was still good before i finish the welding here.
The hinge holes line up spot on now
And this is the gaps.
I'm quite pleased with that.
It's all stripped back down now and i plan to go back out there later and finish the plug welding on the Hinge post.
Ben
#800 Carlos W
Carlos W
  • 10,114 posts
Posted 24 March 2015 - 04:22 PM
Loving your work Ben
#801 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 March 2015 - 05:02 PM
Thankyou mate!
#802 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 March 2015 - 05:11 PM
well the hinge post is in and finished now. didn't take long at all.
I began by cleaning the zinc primer off of the plug holes to get a better weld
And then started the task of plugging them all up
Then a few more slugs inside the post
Then a tickle with the grinder. I had a thick grinding stone in for this
With the bulk removed, i went over it with a cutting disc as this gives greater control and then went over the whole lot with a fine flap disc followed by a quick polish with a filment brush
And the same goes for inside the post. It is important to remove any burnt paint from welding before going over with more.
And then a splash of Zinc
And finished!
Ben
#803 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 24 March 2015 - 05:24 PM
Really impressed benjo
#804 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 March 2015 - 05:27 PM
Thankyou matey. It is going quite well at the mo.
There is just so much more work involved in sorting just that corner, far more than i imagined that's for sure!
#805 alchall
alchall
  • Just Joined
  • 604 posts
Posted 24 March 2015 - 05:30 PM
Looks spot on!
I've taken a lesson from this and ordered wings and front panel so I can clamp everything up before committing to welding the inner wings in place!
#806 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 24 March 2015 - 05:57 PM
Awesome job of that. I really like threads like this - they give one an opportunity to do a job properly.
#807 Minidarren83
Minidarren83
  • 1,207 posts
Posted 24 March 2015 - 07:19 PM
Looking good Ben same repairs as I did makes me wish I had welding left to do
#808 carthorse
carthorse
  • 257 posts
Posted 24 March 2015 - 10:29 PM
After Reading the whole thread from start to finish over the last couple of nights I think it's a massive credit to you that your only a few mm out after the amount of metal you've replaced! That door / A panel gaps as good as anything that came out of the factory apart from one little section.
I aspire to have the both the skill and patience to finish welds to your standard
#809 big-jay
big-jay
  • 518 posts
Posted 24 March 2015 - 10:53 PM
Brilliant Ben,
Your welding looks spot on, such a tidy repair !
#810 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 March 2015 - 08:23 AM
Cheers Guys. Much appreciated. I'm hoping to do all the prep today so i can get the inner wing on.
And Carthorse, the measurement Pete helped me with is now exactly 50" after some fettling  :D
Ill not worry about the door gaps too much right now as i need to replace the door skin so ill get them spot on once the new skin is on.
Ben
