* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#781 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 March 2015 - 10:52 PM
Right, i have now finalised what needs to be done to get the panels into their final position.
It turns out that the bottom of the windscreen boxing panel that i replaced is fowling against the top of the inner wing behind the dash top rail and that is what is stopping it going over.
Ill get all the panels taken back off hopefully sunday and then i should soon be ready to finally get them welded on!
Ben
#782 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 05:30 PM
Stripped it all down again today to sort the issue with the boxing panel
You can see where the problem lies
Which was causing the top of the inner wing to sit proud
Back to basics.
And then i re-shaped the boxing panel.
with that done, i stripped the e-coat from the A post and reinforcing panel and then marked out the plug holes with a marker pen
And then drilled some 6mm holes using a step cutter
I then had to de-burr the backs of the holes
Before:
After a tickle with a 1mm cutting disc
And then on with some zinc primer
And the bare metaled reinforcer
And Zinc
Then tried it in place
I made 2 small mistakes with plug hole placement but it's no bother.
And tomorrow, i need to replace this flange and then i can build it back up again
Ben
#783 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 09:17 PM
Does anyone have any pictures of the back edge of the flitch without an A panel fitted so i can see how it fits top and bottom?
I can't compare with the other side on mine as it's missing.
I need to see how the flange that the A panel wraps around sits in relation to the square cut out on the front edge of the door step flange before i weld anything.
Ben
Edited by Ben_O, 21 March 2015 - 09:17 PM.
#784 Petrol
Petrol
  • 967 posts
Posted 21 March 2015 - 09:28 PM
Ben, Post a pic up of the exact area and I will have a look.
Pete
#785 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 09:30 PM
Pete
Here
And here
It just doesn't look right to me.
#786 Petrol
Petrol
  • 967 posts
Posted 21 March 2015 - 09:49 PM
Pre strip down pics might be best. These are original size but cropped
Any good?
Pete
Might have some more
#787 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 09:52 PM
Any good?
Pete
They are just the ticket Pete. Thankyou very much for that. Looks like i'm not too far off then.
Lovely!
Ben
#788 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 09:53 PM
Looking again, it looks like my inner wing needs to go up a bit
#789 Stu.
Stu.
  • 912 posts
Posted 21 March 2015 - 09:54 PM
Ben, Looks like its too low to me. The leading edge of the inner wing should sit inside over the sill seam.
Edited by Stu., 21 March 2015 - 09:55 PM.
#790 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 09:58 PM
It is too low but i know i'm not going to be able to bring it up enough to make it where it should be.
I think i'm going to have to trim it and move the bottom up to make up the difference.
Skullduggery
#791 Stu.
Stu.
  • 912 posts
Posted 21 March 2015 - 10:05 PM
Seems a bit odd its not in the right position as your hinge bolt holes line up vertically.
#792 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 10:10 PM
I know. The whole inner wing is a poor fit. i wonder if i have a dud one?
The first thing i noticed is that the bottom of the flange that the A panel wraps round is not squared off and the bottom of the inner wing where it fits to the toe board and floor is about 10mm away from fitting flush to the floor etc.
Like you say though, the hinge holes line up well and the door is about the right height etc.
I did think that the floor/inner sill and A post might be too high which would be a major bummer but it is perfectly level.
It's really puzzling me and i don't want to have to cut the bottom off of the inner wing to move it up unless i have no other choice..
Ill have to put on my thinking cap
#793 rooney123
rooney123
  • 114 posts
Posted 22 March 2015 - 10:42 AM
keep battling my friend (Rome wasn't built in a day) im sure with a bit of ben_o thinking problem will be solved and live for day :proud:
#794 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 March 2015 - 01:54 PM
Cheers mate. I will get there. This is the first Mini i have worked on body wise and although most aspects are just common sense, this got me wondering.After all, i don't want to weld anything in this crucial area until i'm certain.
Ben
#795 rooney123
rooney123
  • 114 posts
Posted 22 March 2015 - 03:16 PM
that's true don't want be welding things then having to redo them there's no truer saying than, measure twice cut once!................ :proud: andy
