* * - - - 3 votes
Mini 25 Full Rebuild
1498 replies to this topic
#736 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2015 - 11:52 PM
Still watching and looking good Ben :thumbsup:
I have used quite a few of those filament brushes and find the 100mm ones better. Since the bristles are longer and more flexible, they penetrate into crevices much better. They also work out a lot cheaper in the long run. I have also used the blue ones which are much finer - great for polishing alloy.
LOLs at the "breakers yard garage" :D  Mine is pretty much the same at the moment. I guess we all have too much stuff and not enough room :teehee:
Pete
Thanks Pete.
I have sorted out in the garage now. I had all of the engine components from my car plus all the parts i had to remove to get said parts off piled up in there and then all of the same parts from the donor car piled up on top plus all the bulky parts like headlights, arch liners, bumpers, ductwork, wheels etc.
Still, only another day or two until i get the job finished and then i can clear it right out, do a tip run and then get cracking with the Mini.
Ben
#737 Spud21
Spud21
  • 67 posts
Posted 27 February 2015 - 12:59 PM
Just finished reading this from start to finish, great work so far, and some lovely fabrication work :)
Looking forward to more updates.
#738 finch661
finch661
  • 2,340 posts
Posted 27 February 2015 - 01:24 PM
looking good buddy!
#739 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 February 2015 - 07:35 PM
Cheers fellas
#740 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 02 March 2015 - 11:06 PM
Finally had a chance to finish reading all of this, fair play ben some great work going in to this!
Any updates? did want the reading to end haha. :proud:
Mark.
#741 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 March 2015 - 02:09 AM
Mark.
Thanks for taking the time to read it :-)
I now have all of the panels to complete the o/s of the car but progress has come to a halt as i have had another little project to finish.
Ill be going back to the Mini probably next week and should soon see the o/s finished which leaves a comparatively small amount of work to complete to finish the car ready for prep. The o/s was definitely by far the worst part of the car.
Ben
#742 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2015 - 04:47 PM
Managed to get the garage sorted finally so took some better pics of the new panels.
work will probably commence next week
Ben
#743 Ellie
Ellie
  • 298 posts
Posted 07 March 2015 - 05:03 PM
When shall I bring mine round then Ben?
#744 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2015 - 05:12 PM
When mine is done if you like
#745 SAL 821X
SAL 821X
  • 1,891 posts
Posted 07 March 2015 - 05:19 PM
Cha-Ching.....! some panels there Ben.
#746 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2015 - 05:24 PM
Yes mate.Not pictured are the Quarter panel, full heritage inner wing and the outer wing etc which i will be fitting along with this lot.
Well i say fitting the wing, infact i shall just use it to see what the gaps are like etc. I won't fit that until the end
#747 rooney123
rooney123
  • 114 posts
Posted 07 March 2015 - 08:20 PM
like to see nice new parts......................... :highfive:
#748 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 08 March 2015 - 11:20 AM
Looking good.
#749 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 March 2015 - 05:13 PM
Had a little play with the door and hinge panel today.
With the hinge panel fitted and the door on, there is a lovely even gap with just one spacer on each hinge.
I forgot to get photos before i took the door back off.
I put the inner wing in place and managed to get the top hinge holes to line up almost but the bottom is very far out.
But i quickly found the cause after seeing this HUUGGEE gap
And this is the problem... My bulkhead repair has too much material in the way which is stopping the inner wing going over.
Ill trim it up and then it should all be fine. The whole thing needs to go up too but i believe the bulkhead repair is preventing this too.
More to come...
Ben
#750 lyndseyp27
lyndseyp27
    A little bit little
  • 600 posts
Posted 11 March 2015 - 10:33 PM
Is this still not finished, Ben. :( I can't wait forever for you to do mine! hehe
Any plans over the pond yet?!
