Been at it again today.
I want to get the shell ready to accept the arch tub so i can get it in ready for the fitting of the heelboard etc.
First of all i set about cutting out the right hand rear seat belt anchorage as it is a bit tired and there is rust beneath it. The mount itself is spot welded to the bulkhead and then there are a few random tack welds and a couple of inch long seam welds holding it to the bulkhead and boot floor.
So i chopped it off ready for the clean up.
Then i gave the whole area a through clean up to see what needed repairing etc
The flange of the rear bulkhead where it spot welds to the arch tub was a bit thin in places and there was some tears/cuts from where i had removed the seat belt anchorage. so i decided that i would make up a new piece to stitch in.
As you can see in this next photo, there is a lovely tear where a seam weld was holding the anchorage to the bulkhead and it was to thin on the edges to weld it up.
I'm quite happy with the fit of the arch tub, it fit's nice and close to all of the places it needs to weld to.
Another close up of that tear and cut
So i made up a cardboard template to follow the existing shape and tried it in for fit.
Then transferred it onto steel
Cut it out and cleaned it back to bare metal
And then using 2 pairs of pliers, i put the fold into it and then finished it off with a hammer and dolly to get this
So then i drew a guide line on the old one so it could be cut out to allow the new one in
And then put some masking tape on the arch tub and re-fitted it so i could draw an outline of the old flange onto it as a guide for fitting the new one
Then i carefully cut it out with a 1mm disc leaving my guide line to work against.
I don't seem to have taken any pics of the next stage but here it is partially welded in and cleaned up
And from the back
I had to stop, because this happened
the next update will have to be after i have got some more wire. Hopefully by then, i will have the other panels too.
Cheers for looking
Ben
Edited by Ben_O, 07 February 2015 - 05:26 PM.
