Not felt much like doing any panel work lately what with the eye injury followed swiftly with Flu which still hasn't completely cleared up.
The stupid Brook beside our house has been plating up again and overflowing onto the footpath so in fear of a repeat of last years fun and games i decided i would prepare myself and with the garage being in it's usual chaotic mess, i decided to have a clear up and do it properly this time so several tip runs and boring hours later i had it much better and much more usable.
I also moved my work bench as with it where it was, i kept putting stuff in front of it meaning i couldn't get near it to actually use it
I also made a makeshift shelving solution out of some scrap wood. Not pretty by any stretch of the imagination but it's got some floor space back
and the bench in it's new better position
Anyway, in the spirit of keeping this project going i decided to have a go at stripping the front suspension and get it cleaned up which led to a problem later on...
So here are the wonderful rusty top arms with trumpets
One set stripped
And the other
I will be replacing the Knuckle joints and cups as well as the shocker bolt and collar, the rest will clean up and be re-used. wel apart from the doughnuts obviously...
Here was the first problem...
The grease nipple has been sheared off in the past so i will either drill and tap it or just use another arm.
So i cleaned up the 'good' arm which looks like this
Came up pretty well with minimal effort. It will have a soak in some vinegar to get at the rest of the rust before paint.
And here is the second problem.
I can't get the bloody needle bearing casings out.
The needles and outer collar came out
But i am left with this.
Any ideas on how to remove them??
Ben
