I'll Be There In A Jiffy!
kit-car
161 replies to this topic
#1 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 03 May 2013 - 08:43 AM
So yesterday I made a 400 mile round trip to collect one of the most Marmite cars I have ever laid eyes on. Fortunately I absolutely love it!
464143_10151571266338252_846752398_o_zps
904641_10151571266148252_1591100927_o_zp
Its an Indespension (as in the trailer company) Jiffy. Although the company wasn't called Indespension at the time. It was a kit car offered in the 80s that you could buy in bits or as a rolling chassis.
I have a feeling this one was bought as a kit as the Mini bits are significantly older than the registration date. Ive managed to date the front subframe, engine and loom to a 1973 Mini 1000 and even have the registration plate of said deceased Mini. The fuel tank is a pick-up one and the speedo is from something a bit later I think as its an offset twin clock.
As you can see its currently in pieces but its all there (mostly!). Im hoping to have an MOT on it in time for Himley. However, I feel a Shifty moment coming on here! How long ago was that MPi meant to be ready Sean??
Current list of missing/replacement parts required:
  • Wiring - The loom is there but there isnt much left that useable and the cabling is pretty crusty. Ill probably wire something up from scratch using the old plugs and relays. It has no heater, radio, or washer motor (bellow washer pump!) so the loom is going to be pretty basic! The ignition system is still wired up without the ignition barrel so the lights is the main thing to do.
  • 4/5 New tyres
  • Copper brake and clutch lines for master cylinders.
  • Fuel line
  • Horn
  • Ignition barrel (and keys!) and stalks.
  • Muffler - It has piping right up to the backbox but no backbox!
  • Air filter/housing - Might just go aftermarket cone for simplicity.
  • Door seals - standard Mini ones.
Thats about it really! Im going to have another look round it tonight and check if there is anything else missing. Ill keep this thread updated and if anyone has any of the above parts going cheap drop me a PM.
Edited by Tommyboy12, 03 May 2013 - 08:45 AM.
#2 js183379
js183379
  • 130 posts
Posted 03 May 2013 - 08:55 AM
WANT.  Nice find!!!!
#3 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 03 May 2013 - 09:21 AM
Thanks! I forgot to mention the plans:
I want to sand down and repaint the wood slats in a dark green and replace the bed floor which is made of rotten ply-board at the moment! Repaint the ironmongery in black and replace a few missing catches on the bed. At the moment the sides cant hold themselves up.
Then its going to get a camouflage-style vinyl wrap! I think it will look the dogs doo-dahs!
#4 MINI WILL
MINI WILL
  • 559 posts
Posted 03 May 2013 - 02:47 PM
Looks a fun project, i bet you'll have it done in a jiffy!
:proud:
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 03 May 2013 - 04:44 PM
Pah, the whole point of having a deadline is to know just how far behind schedule you are!!
Looks pretty good, better get a wiggle on if you want to make Himley!!
#6 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 03 May 2013 - 09:42 PM
Took some more photos this afternoon:
One 998cc A-Series complete with dubious looking dynamo and remote gear change. Im glad there isnt much current draw on that dynamo to be honest!
Fibreglass dashboard to go with a rather spartan cab. The only creature comfort is a rubber mat for flooring!
Rather worn looking MG Metro steering wheel. A heater unit is meant to sit to the right of the steering column where that slot is however it didnt come with one in, the plumbing is done without one and Im stripping those wires out of the loom. So I will probably fill that space up!
Flat-bed with doors, bonnet and fuel tank.
Rear springs with a solid axle.
Original Jiffy sticker on the nose.
I also found this rather unusual mark. It seems someone has brazed it with a coin of some description!
[url=http://s53.photobucket.com/user/Dkmode1989/media/Jiffy/20130503_173140_zpsecfb9f59.jpg.html]20130503_173140_zpsecfb9f59.jpg
I made a start on the wiring loom tonight. There isnt much left of it apart from the main plugs under the dashboard and the voltage regulator. Luckily all the main plugs are there although I spent 90 minutes tonight soldering the speedo plug back onto the loom!
473280_10151573132978252_841307521_o_zps
Edited by Tommyboy12, 03 May 2013 - 09:49 PM.
#7 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 04 May 2013 - 07:29 AM
Are you keeping the seats??
#8 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 04 May 2013 - 07:47 AM
Lol I'd love that
#9 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 04 May 2013 - 11:43 AM
Probably will keep the seats yeah. They are in pretty good nick. Unless something nicer comes up for cheap enough.
#10 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 04 May 2013 - 02:22 PM
Spent the last few hours sorting out the wiring. Its pretty much finished apart from the bits of the loom which can only be put in in the car.
#11 Gadgets
Gadgets
  • 471 posts
Posted 04 May 2013 - 03:56 PM
Cracking find, I look forward to watching your progress with the resto.
#12 cityspeed
cityspeed
  • 193 posts
Posted 04 May 2013 - 05:43 PM
Never seen one of these before, Will be keeping an eye on it as its very different! (in a nice way :proud: )
#13 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 May 2013 - 05:46 PM
this the one from retrorides? good price if so, i am <50miles away but havent got the space or id have had it myself.
#14 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 04 May 2013 - 05:57 PM
It was the one from Retro Rides yeah. I was debating buying it from pretty much the day it was listed! It was the distance that put me off but I took the plunge in the end.
#15 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 May 2013 - 06:06 PM
yeah bargain and cool.
Also tagged with one or more of these keywords: kit-car
