Stancing A 1990 Checkmate (Well Hopefully)
178 replies to this topic
#151 doormatt
doormatt
  • 233 posts
Posted 24 June 2016 - 02:54 PM
This is looking pretty cool. love the look of the car. That players classic looked pretty good might have to go next year..
So worth going to, the variety of cars there is insane
#152 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 25 June 2016 - 11:40 AM
Looks amazing, proper nice :wub:
#153 doormatt
doormatt
  • 233 posts
Posted 12 August 2016 - 12:40 AM
Right now ladies and gentlemen, about time for a big update and to reveal what I have been working on for over a year.
Before I start I have to stress how many problems I have had trying to get this kit together. Had a lot of problems with the company that supplied the kit which I'm not going to go into but long story short, the kit didn't work and I've had to build my own kit using a box of parts.
Also I should say that I have never looked at how an air ride kit is built, nor have I ever done any wiring before in my life. Therefore this has been a completely new experience for me and I've had to learn wiring and air ride in the space of 2 days! As you can probably tell by now from my forum thread I'm not a mechanically minded person and I've never been taught anything so this was a bloody tough task and its not a clean install by any means but it will be redone at some point now I have some experience, so please don't judge some of the wiring and let me know if there are some glaring problems.
And now for what I've been building up to, yes I am putting my mini on bags (air ride). Finally I can start to live up to the name of this topic!
To start off I mocked up where I wanted the tank and compressor. The tank sat at the front of the boot to give space for the air line coming up from the compressor and to show off my amp still. The compressor sits in the spare wheel well and helps to prop up the boot floor;
I was never given any instructions with my kit so I had to 'improvise' and used these which were for a dual compressor setup on a chevy s10 pickup...only slightly different to a single compressor system on a mini;
I lined up all the solenoids in order for front and rear so I knew what I was wiring up and then I cracked on;
My next step was to put the compressor in place and fixed down so I could start fixing in all the other components and start to wire it all up;
Once this was done I threaded an airline through to the front dashboard where I was going to put the solenoids for the front. I tried as best as I could to hide the airline under the carpet and rear seat as I don't really want bright red lines as an eyesore throughout the interior;
I then setup the solenoids in the dash where they are going to live until I can afford a digital management system;
My next job was to install a fuse box for the relay (for the tank and compressor) and for the live wires running power to the switches for the solenoids;
Once this was place and the relay setup I was able to run wires from the front solenoids to the switch box;
I ran the wires through the bottom of the dash and under the carpets again to hide them;
Here you can see my glamorous assistant soldering some wires together from a butchered land rover dash loom as I seriously underestimated how much wire I would need for this;
Once the front was in place I was able to get the rear solenoids set up, there are 2 per bag (1 for air in and 1 for air out, basic really), as you can see they fit snugly next to the compressor in the boot;
Once I had these setup and wired through, in the same hole the airline runs through the boot was starting to look something like this (yes I could kinda understand what i was looking at). As I said it wasn't pretty but it was working so far. I had the compressor all wired up to the relay, the live wires running to the switches, the wires running from the solenoids to the switches, and the air lines for the 2 air ports in the tank. Lots of wiring in a very small space!;
Next, my clever idea for the switch box, here you can see a boring and crusty old ash tray and a hole in the floor which was a nice rectangular shape ( I'm sure you can see where this is going). As I had 2 solenoids at the front and 2 at the back I needed somewhere in the middle to wire them both to. Therefore the ash tray worked perfectly. Chris made some templates and then bent up a box to fit over the top. He then marked up and drilled out the holes for the switches. While he did some more soldering I did my fair share of filing to get the holes to the right shape for the switches. Once it was all looking good I gave it a good coat of black paint so it would hide away and match the black carpet. I wired up all the switches, tucking the wires under the carpet to hide them as best as I could. I wasn't too happy with how this went so this will definitely be redone when I have the time! Wiring these up was a pain in the backside and seemed to take forever. As you could expect from someone who has never wired before I had a few problems and ended up rewiring one of the solenoids but 1 out of 8 is pretty good going in my books;
This was all done and I put the interior back in and did my best to make sure everything was hidden. Didn't turn out perfect but it will do for now until I can redo the whole system;
Holes were cut in the floor of my boot build for all of the various wires running to the tank and the tank was put back in place. Many people run copper hardline in their boot builds but I was only given plastic lines. I was actually lucky with that because the lines were red (matching the car) and the were nice and flexible (unlike copper hardline) making my first time setting up and air ride system slightly easier;
Everything was set up but I had one big problem. After wiring up the relay to the ignition (as suggested) the compressor wouldn't stay on. I tried wiring it to other wires on the ignition and ended up stopping my mini from starting at all. However I managed to fix that and wired the relay to my switch for my LEDs. This means I can turn on my compressor whenever I want, however I will need to get a new switch for the LEDs at some point. This picture is when the LEDs were working and the compressor wasn't;
I was happy with how the boot build turned out and with how the whole system turned out for not only my first attempt at air ride but my first attempt at wiring. After some fault finding and testing the system seemed to work and air would blow out of each T join which will run to each bag. I plugged in a rear bag and tried the system. The bag inflated and deflated so I see it as a success!
The mini is now off getting the rear air shocks fitted and brackets made for the front shocks to be fitted. Although I would've liked have done this myself it was way, waaaay out of my comfort zone and my (limited) abilities.
Next update should hopefully be with all the bags fitted and wired up and testing out the system on the car!
#154 Chris1992
Chris1992
  • 2,022 posts
Posted 12 August 2016 - 01:25 AM
WHY DOES MY HAIR LOOK SO DAMN GINGER IN THAT PIC!!??
On another note, this is going to be sexy as hell.
#155 doormatt
doormatt
  • 233 posts
Posted 12 August 2016 - 01:29 AM
But what if Chris is not blonde but ginger ?!?!
Edited by doormatt, 15 January 2017 - 11:16 AM.
#156 doormatt
doormatt
  • 233 posts
Posted 12 August 2016 - 01:32 AM
Also forgot to mention I updated my dash a bit by taking the stupid material off the glove box handle, sprayed it black along with two washer sprayed black to clean up the indicators on the dash. Small changes but cleans up the whole thing
#157 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 12 August 2016 - 04:08 PM
Can't wait to see how this turns out!
#158 doormatt
doormatt
  • 233 posts
Posted 15 January 2017 - 11:10 AM
Welcome to the next addition of what the hell am I doing to my mini.
After all the faff with manual I decided it was the worst idea ever so I've converted to airlift performance V2 digital management. It's so much better, neater and, what I should've done in the first place.
I've also found some front shocks that fit which are off a classic beetle. I've had Harvey Rice at H R Engineering make me some brackets for the front mounts and run all the lines underneath the car (please excuse the state of the underside of my car, I don't think it's had a thorough clean since July as I've been at uni). And it finally works, not quite how I want it to yet though...
B03AACEA-724F-4A4F-9DD6-B05A6C8CA6D0_zps
16DF6A6F-C911-4C77-9498-85938583F0AB_zps
665F4B17-ADEA-49AC-BEF2-36AE6F528A2C_zps
9F5557D9-0801-40FA-8C12-0DD35A86DDA9_zps
http://rs1276.pbsrc....&h=160&fit=clip
It's got plenty of travel and I certainly won't be having any problems with speed bumps, fords, floods, snow, small mountains anymore but as you can see it still sits off the arch by about an inch and I want to get it to be sitting on the arches. My plan is to sort out something with the front bump stops to get it down that bit more at the front and raise the rear shock towers. Only thing I need to watch out for is how close the top of the shock towers are to the fuel tank as I can't imagine I have much room to play with. Any suggestions?
That's all I've got for now but it's going to be sitting on the arches and the arches are going to be sprayed body colour ready for show season, next year is when some more big changes come.
#159 Carlos W
Carlos W
  • 10,114 posts
Posted 15 January 2017 - 12:49 PM
I wish I could've raised mine up like that yesterday when trying to fit the back box.
It wasn't that high even on ramps
#160 doormatt
doormatt
  • 233 posts
Posted 15 January 2017 - 01:40 PM
It's going to come in so useful for little things like that! I had a beaming smile when I drove it home and there was a flood and I could just raise it up and drive through without worrying the water was going to come in
#161 g111mds
g111mds
  • 432 posts
Posted 15 January 2017 - 05:05 PM
No idea how I've missed this, but what a crackin mini!!
#162 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 15 January 2017 - 09:21 PM
Your arches seem to have shrunk... 😔
What happened with the Mexicos?
#163 doormatt
doormatt
  • 233 posts
Posted 15 January 2017 - 10:02 PM
Gone for smaller arches to get better fitment, was over arching with the Mexicos so they had to go
#164 59 Speed
59 Speed
  • 674 posts
Posted 15 January 2017 - 10:36 PM
Boo!
Only joking, it's nice to have a change now and again. Looks good with the new ones on.
I'm going to stick with mine for now, probably have a go at extending them downwards to get the wheel further into the arch. And if / when I get bored of them, I'll stick something narrower on.
Keep up the good work :)
#165 coopdog
coopdog
  • 4,506 posts
Posted 16 January 2017 - 12:09 AM
Bbbaaaaannnhgggggiiiimnnnnngggggggggg
