If you were to use a different shell with the ID of the original car, who is going to know??
Reshelling...
#16
Posted 28 April 2013 - 09:05 PM
#17
Posted 28 April 2013 - 09:08 PM
would that be the same mark shell ?
#18
Posted 28 April 2013 - 09:14 PM
until the dvla have in interest in why the chassis number on the vin plate and the stamped in scuttle number (from the late 70's onwards) don't match and suspect it's either stolen, cloned or a ringer and then crush it.
#19
Posted 28 April 2013 - 09:38 PM
The thing is there are differences in shells even within the same so-called mark. The changes were tiny over the years but they are there. If the DVLA or VOSA are suspicious they send the car for a VIC check and if the tester is still suspicious they appoint someone, usually from a club, who is an expert in the field. Believe me, there are people at the main clubs who know exactly when the shape of the wiring clips welded to the body changed and stuff like that. They would write a report and if there were any small items out of place it would be obvious to them. Also remember these rules aren't written for Minis, they are for all cars. Some cars are harder to ring than others because of the way the rules work, but those that are easy to do but still desirable are the ones the authorities are going to be most interested in.
#20
Posted 28 April 2013 - 10:50 PM
Some interesting comments on DVLA inspections below.......which are similar to my experiences.
Quote:
"It's fair to say that when you do eventually present your car the (DVLA) person inspecting it won't know the back end from the front nor a Rover Cooper from a '59 and actually I've heard of people lifting "cherished" number plates off early Mini logbooks by taking a vaguely similar example down to the VRO with the ID plates from a dead or un-MOT-able car screwed on, all they do is take a note of the numbers, the car itself is irrelevant unless it's very obviously a non Mini."
http://forum.minicoo...?t=17419&page=2
#21
Posted 28 April 2013 - 11:15 PM
The first rule of fight club is.........
#22
Posted 29 April 2013 - 03:54 PM
You do what you have to do to keep such cars on the road, but you just don't keep talking about it.
#23
Posted 30 April 2013 - 08:06 AM
#24
Posted 30 April 2013 - 08:35 AM
a 1965 mini 850 with cooper s bits is worth a lot less than a 1965 cooper s
that's why ID's get swapped
#25
Posted 30 April 2013 - 11:33 AM
#26
Posted 30 April 2013 - 11:34 AM
#27
Posted 30 April 2013 - 08:53 PM
When Jason went in search of the fleece he set sail in a brand new ship, the Argo. His adventures lasted many years and the Argo was damaged time and time again. The hull was smashed, the mast broken, rigging torn away and sails ripped. Each time it was repaired with materials at hand and set off again to continue the voyage. Some items were repaired many times over.
When the Argonauts finally returned home, there was not one plank, one nail or a single piece of rope that survived from the day of its launch.
So tell me DVLA is it still the same ship?
#28
Posted 30 April 2013 - 10:13 PM
/\ I was thinking Triggers Broom but it's the same concept. /\
#29
Posted 30 April 2013 - 11:39 PM
I can never understand the paranoia about re-shelling. Ever since the Mini was introduced they have been re-shelled after accidents or when seriously corroded.
It is, of course, not acceptable if the idea is to re-shell in order to create a road tax free car, but to preserve early cars is another matter.
A Mk.1 shell is a Mk.1 shell. There are no structural differences between the 850, 998 Cooper or Cooper 'S' and the shells just had a BMC part number as a sub-assembly.
The gov't, in the form of DVLA have simply complicated things and screwed up the classic car movement with unenforceable regulations. There is, in practice, no way of telling one early shell from another and even the works rally cars were re-shelled and not always with new shells either.
Just about every historic rally Cooper 'S' has been re-shelled at least once. Would it have been better to have broken those cars up and sold off the re-useable bits? Would that make the 'body-shell police' happy?
As I and others have said before, do what you have to do to preserve your original specification Mini, but don't keep talking about it on here!
#30
Posted 01 May 2013 - 08:58 AM
The problem is that it would be almost impossible to write a law that made it illegal to reshell for the purposes of ringing a stolen car or other fraudulent use, but made it legal for everyone else.
