hey guys some im coming to wire my mega jolt up and have got a couple of questions , 1 being where would i pick my 12v feed up from to power the megajolt and the edis . what would the benefits of having 2 maps that you can swap between be on the a series engine ?
![Photo](https://secure.gravatar.com/avatar/baae9921c505ac01d07d03c72626425b?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
3 replies to this topic
Posted 24 April 2013 - 09:23 AM
Posted 24 April 2013 - 09:30 AM
I took the power for the megajolt from the ignition live on the fusebox. I also wired up a switch for the 2 Map thing but after getting it tuned on the dyno i realised there wasn't any reason to switch to another map.
Posted 24 April 2013 - 12:42 PM
Use the original ignition supply and keep your earths separate from those for other circuits (lights, wipers etc.).
Posted 24 April 2013 - 02:09 PM
Or a high and low boost map...
Mini Technical Sections →
Problems, Questions and Technical →
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
