Brake Bleeding Nipple Spanner Size
neiloliver
, Apr 23 2013 09:30 PM
9 replies to this topic
Posted 23 April 2013 - 09:30 PM
I want to bleed the brakes on my 1975 850DL (Drums all round, single circuit). I have not done this before so just had a look this evening whilst checking the shoes and adjusting them. The nipples were rather covered in crud so I have cleaned them. I assume I open them by turning 3/4 of a turn like is says in the H manual but none of my imperial spanners fit. Are they metric?
Thank you
N
Thank you
N
Posted 23 April 2013 - 09:31 PM
More than likely 7mm. You may find though they could be corroded in place so plenty of penetrating fluid will help here.
Posted 23 April 2013 - 09:34 PM
They used to be 1/4 af but the rust could have changed that, if there that rusty then fit new is my advice
Posted 23 April 2013 - 09:35 PM
Get yourself a set of these
http://www.ebay.co.u...ke-pipe-spanner
Will save you a lot of heart ache
Trac
Trac
Posted 23 April 2013 - 09:36 PM
Thats if they are original. The new slaves i have fitted to the back of Paddy have 7 mm bleed nipples.. Too small by far.
Posted 24 April 2013 - 04:29 PM
I would also recommend using a proper spanner for the job.
Posted 24 April 2013 - 08:00 PM
silly question, but how does the nipple work? (I was bottle fed). When i turn it, is it in two pieces or will it part unscrew from the cylinder itself?
N
N
Posted 24 April 2013 - 08:06 PM
It unscrews from the slave cylinder / caliper. It does not need to be fully unscrewed, only enough for fluid to bleed out in a steady stream when its opened.
Posted 24 April 2013 - 08:42 PM
The bleed nipple has a tapered seat and backing it off slightly allows fluid to flow out the internal drilling
Posted 24 April 2013 - 08:55 PM
Thanks guys, now I understand
