Carbon Fibre A-Panels
Posted 23 April 2013 - 07:49 PM
Posted 23 April 2013 - 07:54 PM
Not too sure how carbon A panels will fit to a steel wing either???
That said.....carbon fibre and steel have very different properties in terms of strength. Carbon shatters on impact, whereas steel will fold and bend and absorb the impact.
Posted 23 April 2013 - 08:03 PM
Considering no mini panels use adhesive to attach them then there will always be a question mark with regards to strength. Its the initial argument about the original design etc etc.
Modern adhesives are very very effective and i know this from experience as this technology is used extensively in modern Civil aircraft construction. However this is designed from scratch with this in mind. A mini was built and passed for use using welding technology.
Posted 23 April 2013 - 08:05 PM
Posted 23 April 2013 - 08:16 PM
why do you want to swap the a panels for carbon fiber anyway? seems a bit pointless
Doesn't rust?
Posted 23 April 2013 - 08:18 PM
Doesn't rust?
No but if its all repaired correctly with new metal then protected properly and arch liners installed it shouldnt need doing for a very long time and that would still be cheaper than carbon a panels i would imagine
Plus you still have the front wings and front panel which are steel which will rust plus the sills etc etc
Edited by Alex_B, 23 April 2013 - 08:19 PM.
Posted 23 April 2013 - 08:35 PM
Doesn't rust?
Yeh...i was being sarcastic....i'm with you though.....do it properly in steel and you can forget about it. And it'll be strong and behave well (as well as can be expected) in an impact. I'm thinking the carbon A panel idea is for cosmetic reasons....get stick on stuff...boy racers don't know the difference!.
Posted 23 April 2013 - 08:39 PM
Posted 23 April 2013 - 08:42 PM
Posted 23 April 2013 - 09:04 PM
So is spiders silk but you can't make a car from it! CF is brilliant when it is used in the way it is designed to be used. That is very different to how a mini is put together. It would take too long to explain fully but just replacing the A panel would result in a significant loss of strength if done in a like for like fashion. Even with a full structural adhesive such as DP410 the way it would be loaded in a crash is totally wrong. This comes from experience in designing and building CF monocoques for endurance racing. You have to throw away all your steel monocoque knowledge and do it a completely different way. CF A panels are good for looking nice (if you like that sort of thing) and saving weight - hardly relevant on a road car as there are a thousand better ways to save weight.Carbon fibre is stronger than steel, so i doubt you'd have any reduction in strength at all, if anything you'd gain strength, one question though.... why? is it an ultra lightweight track machine?? if not, i ask again... why :s
Posted 23 April 2013 - 09:12 PM
Posted 23 April 2013 - 09:27 PM
Fiberglass is similar to CF in the way it deforms in an accident ie it doesnt it simply shatters and the front end provides all what little crash protection the mini has, I wouldnt have any legs or at the very least broken legs if my car had a grp front end after my accident in november
Posted 23 April 2013 - 09:40 PM
Yeah very true, I am a biker and have been for many years so not bothered about protection and I don't take passengers in my car.Ok yeah its all ok at the moment but you have lost a lot of structural ridgity and in the event of an accident you could find yourself in a bit of a pickle!
Edited by petey81, 23 April 2013 - 09:41 PM.
Posted 23 April 2013 - 10:11 PM
Also, the pitifully small amount of weight reduction is utterly pointless. You could get much more by just polishing the rough skin off the engine block, without weakening anything.
And, on the basis of dimensions, carbon fibre is NOT as strong as steel, i.e. if it is 0.9mm thick, it does not have the strength, and even more so, stiffness of the standard Mini panel. On the basis of weight, it is stronger, but still less stiff than steel.
If you must waste money on CF, and it is a complete waste on a road car, let it be somewhere harmless like the boot lid, or maybe the roof skin, although a steel roof will be better in some uncommon types of accident.
