Lead Substitute
3 replies to this topic
#1 its_courts28
its_courts28
  • 644 posts
Posted 18 April 2013 - 05:57 PM
What's the difference between castrol valvemaster plus and the normal one? Does it make the car run better? Would I have to use the unleaded octane fuel?
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 18 April 2013 - 05:59 PM
the valve master plus I think is an octane booster as well as lead additive, I use it in mine and it theoretically would be like running with the higher octane fuel but whether it has much effect who knows, although it helped when mine was pinking a little so i think it does :)
#3 its_courts28
its_courts28
  • 644 posts
Posted 18 April 2013 - 06:01 PM
So it's worth a try? Not for any specific reason just wondered what benefits or had over the standard one
#4 Alex_B
Alex_B
  • 4,573 posts
Posted 18 April 2013 - 06:03 PM
well if you are using a lead additive then might as well use one that might make the engine run slightly better, and theres no real reason why not to other than your wallet
