Edited by daenesh, 18 April 2013 - 09:35 AM.
Best Answer Dan , 18 April 2013 - 10:16 AM
The covered nut is a single phase AC positive output (W terminal). The entire alternator body is the earth. DO NOT try to earth any of the terminals on your alternator or you may end up with the car on fire. A127 units are generally only equipped with an earth terminal when they are assembled for marine engines as they then have an isolated casing. When fitted, the earth is on the other side of the 3 pin plug. If it was an earth, it would not come from the factory insulated.
The plug output is fine for A127 units up to 80A output. The stud terminal is used for higher power units. Until recently the casings had either one connection set or the other, but not both. If you don't want to replace the original cables into the plug terminals though adding an additional cable to the stud in this way would work fine.
Go to the full post
Posted 18 April 2013 - 09:33 AM
Posted 18 April 2013 - 10:01 AM
Posted 18 April 2013 - 10:16 AM Best Answer
Edited by Dan, 18 April 2013 - 10:17 AM.
Posted 18 April 2013 - 11:08 AM
Posted 18 April 2013 - 11:22 AM
Posted 18 April 2013 - 02:53 PM
Posted 18 April 2013 - 04:54 PM
Posted 18 April 2013 - 06:29 PM
Posted 18 April 2013 - 07:10 PM
Posted 19 April 2013 - 12:26 PM
Edited by daenesh, 19 April 2013 - 12:26 PM.
