What did you do to get it sitting like this? I love the stance and want to get my saloon sitting like this!
Posted 07 April 2014 - 04:02 PM
Posted 09 April 2014 - 05:59 PM
Seen your posts on the mini stance thread, be very interested to see in depth how you've designed your kit. always something ive wanted to do. maybe the next 1 lol
Posted 09 April 2014 - 07:54 PM
Rear is pretty straight forward. I posted a picture of the shock mount bracket for the front. I am waiting for the 3/16" steel to arrive. If you can imagine, to get the proper drop that I want, this shock will be almost under the top of the fender. And as the top arm goes up, that creates quiet the angle with a bracket on top of the arm. So should be interesting. It will be a very tight squeeze. These shocks are almost 4" in diameter at the top. The picture of the front now the tires are on the fender, so I was going to... relieve... possibly another inch maybe 2 tops, I don't think it will be possible to go that far. Maybe next year I will go the full frame route...
Posted 10 April 2014 - 09:37 PM
Not easy getting a mini body that low. Wonder will it camber the wheels much with the angle it will be at
Posted 11 April 2014 - 02:46 PM
Surprisingly the camber on the front is not bad. I have stock lower arms right now, but also have a set of adjustable on car I may try out later one day. I am worried if too much camber it will catch the air shock when deflated. Looks like my steel won't make it in time for this weekend! So much for paying for 2 day air. Need to find a local shop that stocks it. Anyway, more progress will be made.
Posted 15 April 2014 - 02:32 PM
Posted 15 April 2014 - 07:54 PM
Posted 16 April 2014 - 02:31 PM
Well last night I continued mocking up the front top mounts, looks like I will have to redesign the lower mount to be further out and slightly lower, and raise the top mount by an inch or so... that and do a little more trimming on the top mount to get a little more clearance for everything. But it looks like it will work. Extremely tight though!
My new top mount, coilover top mount, and stock shock mount for Classic Mini.
I cut out the subframe tower, going to flip the part I cut out and reweld in so it is concave, or I might just flat plate it, not sure yet.
Shock all the way extended. I also had to face shock towards inside because air fitting would hit fender... another unexpected small detail, as well as the 9 point shock adjuster will obviously be facing inwards as well.
Here it is fully collapsed. It is binding a bit, this measures 11.5" from eye to eye, it is suppose to collapse to 10.5" or so, so I will trim out the top bracket a little bit, and move that bottom bracket out so it is a little more straight up and down position, as well as move the top mount up 1 more inch or so for tire clearance. I think with a little more tweaking it should work ok.
Posted 17 April 2014 - 02:20 PM
Posted 21 April 2014 - 01:39 PM
Posted 28 April 2014 - 03:17 PM
Posted 28 April 2014 - 03:28 PM
never thought id say this but i think i actually prefer this on 10s now . id still paint the centres black though.
epic work man, wish i could do stuff like this
Posted 28 April 2014 - 07:53 PM
Posted 28 April 2014 - 09:12 PM
The 10's have really grown on me as well. I am on the fence with doing the centers vintage gold or black. I have plastidip I could try on it.
Any idea on the the total cost of the air ? And is it airlift ? I much say its looks amazing 😎
The total cost is around $900 so far. It took forever to find a good deal on the medium stroke airlift shocks, I used a airlifts management, but it's only 2 way setup. I got that just to have cheap on board air, plus I liked the idea that it was wireless, but that has lead to other problems, can't really drive it at low pressure settings because the car tips one side or the other. So in the future I will invest into a fbss setup, small 1 or 3 gallon tank, and a decent size single compressor. That may run this entire setup to $1200 total. Still not bad considering. I am pretty happy with it, just want to be able to drive at a lower pressure, right now I have to have it around 80-90psi so it won't tip/body roll in corners. Would like to be more at 60 or 50psi. Anyway, will update when that occurs at some point.
Posted 28 April 2014 - 09:27 PM
ive seen those wheels done with gold centers quite a few times, but never in black, so black would be my choice... it'll look sweet either way though
