Bmw Cooper S
Posted 16 April 2013 - 08:45 PM
This normal anyone know as may get one later on
Posted 16 April 2013 - 09:00 PM
But they shouldnt be notchy unless you mean the shifter feel, as they do feel a bit clunky if that makes sense
Posted 16 April 2013 - 09:02 PM
Posted 16 April 2013 - 09:22 PM
Touch wood no problems with mine.
Posted 16 April 2013 - 09:56 PM
It should be as noted above 6 speed, the throw is "tight" especially into 1st on mine (Bini Cooper S conv.)
So is a 2002 a mk 1. What year best to get 2005 or later not up on these caes
Posted 16 April 2013 - 10:19 PM
Posted 16 April 2013 - 11:15 PM
My mums only ever owned a mk2 s and i have driven it a few times, the shift is tight as described and a little odd but thats just the way they are
Posted 16 April 2013 - 11:35 PM
2001-July 2004 R50 Mk1 (pre-facelift) MINI Cooper/One has Rover Midland 5-speed gearbox which is known for bearing/diff failures, helps if you change gearbox oil more often...but has a nicer smoother gearchange action than the Getrags.
July 2004-2006 R50 Mk1 (Facelift) MINI Cooper/One has a stronger Getrag 5-speed gearbox.
The MCS Getrag 6-speed is a popular conversion to One/Cooper but needs S driveshafts, etc.
More details here:
http://forum.minicooper.org/showthread.php?t=9643
Edited by mab01uk, 16 April 2013 - 11:39 PM.
Posted 17 April 2013 - 08:23 AM
2002-2006 R53 Mk1 MINI Cooper S has Getrag 6-speed from start of production and is a fairly bullet proof box.
More details here:
So what stay away from the mk1 cooper s the supercharged one didn't they have different gearbox
As well causing failure. So get a turbo one and what year to get is it a mk 2
Posted 17 April 2013 - 08:38 AM
All the first gen S 2002-2006/7 have the getrag 6 speed from 05 ish they have a revised final drive and some had a factory LSD
All of then have a direct slotted feel to each gearshift. Some have suffered for a seizing shifter shaft which is felt as a very stiff side to side movement in the gearstick.
Posted 17 April 2013 - 08:51 AM
The turbo S has its own issues!
I'm starting to get put off getting one
Posted 17 April 2013 - 11:46 AM
The 2002-2006 Mk1 R53 Supercharged MINI Cooper S is strong, reliable and great fun to drive if looked after. The whining supercharger and steering pump all add to the character and are missed on the later Mk2 turbo MINI Cooper S (with better fuel consumption and lower emmisions based road tax).
Useful MINI Buyers Guides here:
http://www.aronline....mini-2001-2007/
http://www.motoringf...3-buyers-guide/
Posted 17 April 2013 - 11:49 AM
Posted 17 April 2013 - 12:17 PM
But many are not maintained and will need work.
Remember some are 12 years old and don't get the love and care a classic would!
Posted 17 April 2013 - 12:23 PM
