Fitting Wind Deflectors
Posted 16 April 2013 - 07:28 AM
Posted 16 April 2013 - 07:31 AM
Also, try putting the bit by the mirror in first and working up towards the front left almost of the window. Then go to the other end of the deflector (widest end) and fit that.
Crap instructions, but hope they helped?
Posted 16 April 2013 - 04:13 PM
Posted 16 April 2013 - 04:37 PM
but i pulled the rubber out and my 2nd hand ones had double sided tape on them, stuck them to the outer edge of the channel the rubber sits in and replaced rubber to hold them in place.
My window doesnt shut fully, i think i need to modify the rubber at the top to allow a wider channel for the glass. When its wound up as far as i can get it, theres a 1/2 cm gap which cannot be seen from outside due to the wind deflector.
Posted 16 April 2013 - 05:01 PM
Posted 16 April 2013 - 05:41 PM
Posted 16 April 2013 - 06:50 PM
www.youtube.com/watch?v=ej1Sc01K1AU
Posted 18 April 2013 - 08:40 AM
Posted 04 June 2013 - 10:29 PM
Bought mine new, no sign of these 3x clip being spoken of. Same trouble really as above would it help replacing the rubbers in the window as no idea if these have gone hard by comparison to a new set
cheers for any thoughts on this
Posted 05 June 2013 - 09:23 AM
Fitted mine in the actual glass channel as said starting at the front bottom corner, not had a problem with them.
Edited by miniman retford, 05 June 2013 - 09:33 AM.
Posted 05 June 2013 - 12:44 PM
didnt think to try that as the guy from W&P explained to pull the rubber out from around the frame and insert it there,
does it move at all sitting in the channel ?
Posted 05 June 2013 - 12:51 PM
No not moved since fitting them about 6 months ago & no problem closing the window.
Posted 05 June 2013 - 06:51 PM
i cant shut my window fully. Mine are fitted by removing the rubber and fitting into the door, then replace rubber.
I need to trim the rubber to give room for the window to go up that last 1cm.
Posted 05 June 2013 - 06:59 PM
I fitted some a couple of weeks back. I just shoved they in the rubber slot where the glass normally sits. That seemed to be what the instructions suggested (but they weren't the best instructions). They went in in about a minute each and the window winds up a treat, no problem.i cant shut my window fully. Mine are fitted by removing the rubber and fitting into the door, then replace rubber.
Posted 05 June 2013 - 07:59 PM
The correct way to fit these is between the glass and the rubber :) don't be tempted to take the seal down and try and fit them between the rubber and the door :) .I had a real struggle to fit mine until I did a bit of google mechanic and found out how to fit them. :)
