Rev Counter Not Working
9 replies to this topic
#1 herdy
herdy
  • 377 posts
  • Local Club: Notts about minis
Posted 15 April 2013 - 09:02 PM
My rev counter started working intermittently and it's gradually working less and less. How would I sort it out? It's a 92 Mayfair with a carb. Thanking you muchly :)
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 April 2013 - 09:10 PM
This is the stand binicle rev counter? Before you answer I would check the connections and does the rev counter jump when you click the ignition on? does it work at all now? and if so whats it reading
#3 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 15 April 2013 - 09:12 PM
Fixed mine by sorting out the earthing on the battery. make sure its bare metal and its not connected to any paint work
#4 herdy
herdy
  • 377 posts
Posted 15 April 2013 - 09:17 PM
I've never noticed it jump even when it was working. It works for like a minute or so but then just dies and reads 0 the majority of the time. It's a standard offset 3 binnacle.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 April 2013 - 09:47 PM
The connections are a problem on the PCB and worth stripping the binicle and checking the circuit board main connections and the connections to the rev counter some have cleaned the connections with a emery board carefully.
#6 jayesmayfair
jayesmayfair
  • 24 posts
Posted 15 April 2013 - 09:50 PM
Check the wires on the back of the clocks.
Theirs a live from the battery (spade terminal) and the trigger wire (bullet terminal) and the earth is on the printed circuit board (if theres a brake in the earth, good luck finding it lol).
If the connections are tight, run an earth to one of the screws that are on the back of the rev counter.
This should solve the problem or tell you if the rev counter needs replacing.
#7 herdy
herdy
  • 377 posts
Posted 15 April 2013 - 09:59 PM
I'll give it a look tomorrow night. Would it fail it's MOT because of it?
#8 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 15 April 2013 - 10:31 PM
It's not an MOT failure
#9 herdy
herdy
  • 377 posts
Posted 16 April 2013 - 07:06 PM
Just noticed that the revcounter does jump when running. Does this change anything?
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 April 2013 - 07:17 PM
still follow the checks is my advice
