Your poll is including Comma Classic and Comma Sonic as the same oil and it is different, like I said earlier...........
#31
Posted 17 August 2013 - 09:17 AM
#32
Posted 17 August 2013 - 10:59 AM
Valvoline VR1 not VH1 Daveeee
#33
Posted 17 August 2013 - 12:43 PM
What you said earlier, so you misread it again then? Its only grouped as a common pair from the same manufacturer. So nothing for you to fall out about. If you use either of those two you tick the box
#34
Posted 17 August 2013 - 12:46 PM
LOL falling out, just pointing out as seems a common mistake on threads I've read where people think there the same. IMHO a point worth making......
#35
Posted 17 August 2013 - 01:30 PM
#36
Posted 17 August 2013 - 04:58 PM
I use Millers Mini stuff. I've used both Halfords and Castrol 20/50 oils and found that after about 2000 miles there is a significant drop in oil pressure, even when cold, so needs changing more frequently.
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
