#16
Posted 14 April 2013 - 08:44 PM
Cold oil pressure 80-85 Hot Oil Pressure 70-75 (these being on idle pressures).
#17
Posted 14 April 2013 - 10:03 PM
#18
Posted 15 April 2013 - 04:59 PM
getting about 80 cold idle, drops to about 50 when warm.
#19
Posted 15 April 2013 - 05:20 PM
I will however be using the Redline oil as i get it through work now.
#20
Posted 15 April 2013 - 06:13 PM
#21
Posted 15 April 2013 - 06:18 PM
Not sure, they definately perform differently in my mgb. I seem to recall the halfords was green, whereas the comma sonic is brown.I was told halfords and comma are the same, just over 60psi cold drops slightly when warm.
#22
Posted 15 April 2013 - 06:29 PM
#23
Posted 15 April 2013 - 07:47 PM
Halfords 20w50 in the mk3 1000, oil pressure drops to about 60psi when warm and 75psi cold.
#24
Posted 24 April 2013 - 01:23 PM
#25
Posted 24 April 2013 - 06:40 PM
What I say to everyone how who asks me is, this is what I use, whatever you use is your choice, but what you should do is check it's condition regularly and change it when it's dark in colour and starts to smell of burning and not fresh oil.
#26
Posted 24 April 2013 - 06:56 PM
Pressure 75 when cold, drops to 50 on tick over when warm, then goes back to about 70 when revved.
#27
Posted 24 April 2013 - 07:09 PM
#28
Posted 24 April 2013 - 07:45 PM
#29
Posted 24 April 2013 - 08:02 PM
#30
Posted 17 August 2013 - 01:08 AM
http://item.mobilewe...Id=130955234639
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
