Roll Cage
Posted 14 April 2013 - 04:40 PM
Posted 14 April 2013 - 05:24 PM
Posted 15 April 2013 - 07:01 PM
Tony
Posted 16 April 2013 - 07:13 PM
Posted 17 April 2013 - 07:08 AM
Posted 17 April 2013 - 11:12 AM
Hey keefr22, I make lists now, so I don't forget stuff. I think it could be an age related thing
Tony
Edited by miniweights, 17 April 2013 - 11:12 AM.
Posted 21 April 2013 - 01:11 PM
I don't doubt it's age related Tony - I do the same but then forget what I've done with the list...!!
Keith
Posted 21 April 2013 - 01:19 PM
Keith
I tend to take pictures when i strip down something new too, to check what goes where for the rebuild... EVERY time i delete them without realising!
Posted 23 April 2013 - 06:36 PM
Posted 25 April 2013 - 05:24 PM
Here's some information Safety Devices give. It may help.
MSA/FIA homologated roll cages: do they all have to be made from 45mm tubing now?
The short answer is no.
Let's use one of our most popular roll cages as an example: the Rover/Austin/British Leyland Classic Mini roll cage N000 (or just N as it was originally called) was made with 38mm tubing and was homologated with such. When you order a N000 roll cage from a Safety Devices Approved Dealer today, the cage will be made at our factory from 38mm tubing, and it will still be a homologated design. You will be able to compete in MSA/FIA events, despite the new rules stating that homologated cages must be made of 45mm tubing.
However, if Safety Devices designed a completely new roll cage for the Classic Mini today, the tubing would need to be made from 45mm tubing.
Notes on homologation
Don't forget that you'll need to produce a genuine homologation certificate to race scrutineers, who will not accept photocopies. Only the MSA can issue genuine homologation certificates. Order directly from the MSA, phone 01753 765000. Certificates cost about £25 and might take up to 2 weeks to reach you by post. The certificate number will generally be listed on our website on your roll cage's page - use the Roll Cage Selector to find your cage.
Homologated roll cages should also display their own, unique homologation sticker. These stickers should never be painted over and will self-destruct if removed to prevent fraudulent use. If you need to replace your Safety Devices homologation sticker, we will need to see photographs of your roll cage. If your cage does not have a homologation sticker, it may have been removed, or the cage might not be homologated.
Look for the unique serial numbers on the footplates of the main hoop behind the driver's or passenger's side and email clear photos to us for verification together with general photos of the roll cage so that we can see its current structure. If the roll cage has been painted over the years, you may need to scrub the paint off the footplates with a wire brush to reveal the serial numbers. You may also need to use a torch to see the serial numbers. Be aware - a cage with a Safety Devices sticker on it does not necessarily mean it’s a Safety Devices cage.
If you don't have an homologation certificate for your particular cage, then you will need to buy one from the MSA, but check first with Rollcentre, you may already have everything required.
Whatever you do, don't give up! It's really not that bad
Tony
Edited by miniweights, 25 April 2013 - 05:30 PM.
Posted 25 April 2013 - 08:12 PM
"We are preparing a classic Mini Clubman, but that won't be ready so intend to use my Seat Ibiza Cupra. This used to be my son's car, & he did one sprint at Llandow in it. On that occcasion he wasn't asked to produce a certificate for the cage. It's a 6 point bolt in Sparco with an FIA homologation sticker showing the serial number but the model number box wasn't filled in when we bought it. We intend running in modprod.
Would anyone know whether we will require to produce a certificate for the cage? "
First reply I had, the poster said this;
"I think it's ok so long as it conforms to the drawings in the blue book, however if it's a road car a cage is not mandatory any way. But if one is fitted it may have to conform to the blue book, if it's an FIA one I doubt it will trouble our speed scrutineers."
If I get any different replies I'll let you know!
Keith
PS the Ibiza, while road legal doesn't conform with standard production class regs (fully stripped interior, lowered suspension etc., so does need a cage
Posted 26 April 2013 - 11:25 AM
I have emailed the MSA, so I will post their reply when/if I receive one.
Tony
Edited by miniweights, 26 April 2013 - 11:25 AM.
Posted 26 April 2013 - 02:25 PM
I do know what you mean though, it's always the worry that you'll end up with a scrute having a bad day & be sent home...!!
Keith
Posted 29 April 2013 - 06:07 PM
Received a reply from the MSA today, and it looks like it's good news Can't think why Safety Devices would say a certificate is required
Here's my email and the reply:
Hi there,
Can you please clarify whether a roll cage homologation certificate is required when competing in stage rallies, hill climbs and sprints, and any other events using MSA regulations?
Many thanks
Tony
Tony,
ROPS certificates will be required where the cage does not meet the basic requirements of the Blue Book section (K) and individual discipline regs.
For cages that do meet these requirements, no additional certification is required.
Regards,
Joe Hickerton
Technical Administrator
The Royal Automobile Club Motor Sports Association Limited
+44(0)1753 765000
Posted 29 April 2013 - 07:29 PM
I've just been reading the blue book K section. It seems the 38mm Safety Devices cage at least will need a certificate as it does not meet the basic requirements which include cages needing to be a minimum bar diameter of 45mm. At least that's the way I see it.
