Austin Mini Mk1 Super Deluxe Restoration
1604 replies to this topic
#1411 CityEPete
CityEPete
  • 3,920 posts
Posted 18 September 2015 - 09:08 PM
Cheers mate , it has no rear wings on at the moment await rear inner wings :-(
 I must admit the wing mirrors would look nice on yours, another thing to make it look older even to a non mini expert, just dont slip! Lol
#1412 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 07:34 AM
I shall take all day on that job no rush or it's a big bill to put right haha. I need to find some original ones tho not sure if they easy to find. I also found a picture from the 1980s it had wing mirrors then.
C551CBA6-38E9-4061-B041-7E9F38C53867_zps
#1413 rhys-89
rhys-89
  • 1,549 posts
  • Local Club: minifreekz
Posted 19 September 2015 - 08:49 AM
If you search desmo mirrors in ebay youll find a load on there new old stock and used if I get a chance later ill measure my wing mirro positions for you
#1414 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:07 PM
thats great thankyou Rhys
#1415 ToM 2012
ToM 2012
  • 4,066 posts
How does the front door cards go in the doors ?
#1416 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:10 PM
0120CFD4-B57F-45B2-BA60-C701DEDE5BDC_zps
#1417 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:11 PM
So much interior fitted A06FBD2B-EF71-498C-A3E0-A1908F7BE897_zps
#1418 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:12 PM
Airvent pipe fitted4E2283E8-71AB-46CE-88A9-0CAF47615995_zps
Edited by ToM 2012, 19 September 2015 - 03:13 PM.
#1419 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:13 PM
32FC90F2-352E-4A74-A9E7-63D634328232_zps
#1420 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:15 PM
3A1EE10F-805B-438D-917D-713811D30F4D_zps
#1421 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:16 PM
9E6D171E-870C-4E6E-AC77-C8A63991CDB7_zps
#1422 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 03:39 PM
Also today I connected push start button up had to cut battery cable and clamp and solder connectors I tried the battery and when I put the positive on the fuel pump is making a noise? Does anyone no why it's doing it? My starter key was out ignition of unless I have put wires on wrong way
#1423 Daz1968
Daz1968
  • 2,058 posts
Posted 19 September 2015 - 06:20 PM
The fuel pump feed goes straight back to fuse box so I suspect if a problem would be at fuse box connections, one fuse is permanent live other live when ignition on, maybe fuel pump connected to incorrect one, is ignition light on when you connected battery as this is also fed from same fuse as pump
#1424 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 September 2015 - 08:09 PM
I will check tomorrow daz I didn't connect it ones I heard the noise as I didn't want fuel pump burning out with out fuel going threw.. Is it ok to leave it on while I check the wires on fuse box thanks Tom
#1425 Rocket.
Rocket.
  • 1,441 posts
Posted 19 September 2015 - 08:27 PM
Tom where did you get the air vent pipe ? been looking for a good alternative to the original for a while now
